Old 01-24-2021, 08:00 AM
It is bloody fun gearing! You can climb anything with it. My old 04 never found a hill it couldn?t get up.
Old 01-25-2021, 09:38 AM
Bryan's Avatar
Bryan Bryan is offline
Originally Posted by Zman View Post
I run 13/52 and really like it. It allows you to crawl in technical areas and I almost never need to slip the clutch.
I run this gearing also. Love it. It allows me to be low in third gear on the trails which still has good maneuverability in tight single track stuff. Can easily blip the throttle allowing the torque to loft the front wheel enough to clear obstacles and with enough momentum to cross logs and roots.
07 EC 300
06 Gold Wing
(2) 06 CRF 150 F
Old 01-25-2021, 11:31 AM
Neil E. Neil E. is offline
13/52 works very well. 1st is useful on hills, 2nd is good for slow speed, 3rd for most single track, 4th for more open single track.
Many guys want to stay in third all the time, but I'd don't mind using fourth.
Old 01-25-2021, 12:06 PM
dANbOT's Avatar
dANbOT dANbOT is offline
13/52 is perfect for my home ST. Minimizes or eliminates the need for clutchwork, and JUST enough legs for steep 1st gear climbs
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 01-25-2021, 01:26 PM
Demi Demi is offline
All really good feedback guys, appreciate it!
Old 01-25-2021, 02:11 PM
On a side note.
The '18 on up bikes have an adjustable rear chain block. Adjust it down to accommodate the bigger rear sprocket.
Old 01-25-2021, 08:32 PM
SS109 SS109 is offline
Wow, I don't know how you guys ride with such steep gearing. I guess here in AZ the top speeds are fast enough that it just wouldn't work for me. I even ride hike-a-bike stuff and do nasty loose hill climbs and never have needed more than 13/48 gearing.
Old 01-25-2021, 09:26 PM
I recently went out on my new to me txt 280 trials bike at a dedicated trials park and to be honest it was the same terrain I ride on my Ec. So I am probably not using the bike as intended but it is so capable.
Old 01-26-2021, 06:08 AM
Pretty interesting feedback, thanks again. Here is a question- would the same chain be able to switch between a 50/52? Wheelbase changed aside...
Old 01-26-2021, 01:12 PM
I have used stock 13/48, 12/48 and 13/51. The 12/48 is the same ratio as your 13/52 but i preferred the handling with the 12/48 over the 13/51 and that boils dowwn to wheelbase. I would think the 13/52 would be even shorter.
The 12/48 was my favourite for the hike-a-bike stuff and i often started off in second. on the asphalt i could still get about 110km/h without wringing its neck too much
gearingcommander.com shows that you will get quicker wear on this ratio as you will have the same tooth connecting with the same chain link every 3 chain revolutions - apparently this determines how quick it will wear, not sure what difference it make
06-300 not running davedunaway Enduro Electrical & Wiring 11 08-29-2012 09:21 AM
running out of fuel? cchracer77 Enduro Intake/Carburetion - 2 stroke 30 03-04-2012 10:20 PM
03 300 not running tophat General Discussions & Announcements 22 08-23-2011 03:51 AM
Running hot Brian VT Enduro Engine - 2 stroke 9 10-01-2008 07:25 AM
Running In Dingo Enduro Engine - 2 stroke 3 07-26-2007 11:36 PM
