Old 01-06-2008, 04:40 PM
steve steve is offline
Default Rebuild
Hello I'm new here,but Ialready have a dumb request.I want to rebuild the bottom end of my 06 ec300. I'm on a small budget,I don't want to buy stuff I don't need.Is there a list of MUST HAVE PARTS to make the job succesfull.Can I get help from one of a gas gas compadres? Thanks Steve
Old 01-06-2008, 04:58 PM
Bottom end already?
I wouldn't approach that trying to go cheap. Do it right. Main bearings, seals, crank rebuild with rod kit, gaskets, plus top end parts.
Old 01-06-2008, 07:45 PM
Originally Posted by GMP View Post
Bottom end already?
I know it might be soon ,I broke my drain plug off and when drilling for the easyout,went to far and punched the drain plug magnet inside the crankcase and can't fish it out,not even with another magnet.The DP magnet is sticking to the metal crankcase parts.So the pre-mature teardown.
Old 01-06-2008, 07:53 PM
what is the approx.cost of b-end rebuild?
Old 01-06-2008, 09:03 PM
It should be easy then, you just need access to the transmission. The ignition side main bearing is a two piece roller, so the cases split easy. The crank can stay in the right side case half. Just gaskets and a new clutch basket washer should do it, if the top end is fresh.
Old 01-07-2008, 12:12 PM
Do you guys think the dp magnet will grind up and not cause any damage?I'm almost willing to take that chance,it's small and briddle mabey it will grind to dust!Hell,I,ve seen motors eat worse,no.Will somebody enable my stupidty,please,ha ha.
rebuild time?? W8TSON Enduro Engine - 2 stroke 10 08-02-2009 02:05 PM
125 rebuild chronicle noobi Enduro Engine - 2 stroke 9 06-25-2009 04:12 AM
Need help on top end rebuild rpduc Enduro Engine - 2 stroke 17 03-26-2009 11:05 PM
05 rebuild brains Enduro Suspension 2 07-22-2008 08:54 AM
Lower End Rebuild PEB Enduro Engine - 2 stroke 1 10-06-2006 06:36 PM
