Old 07-31-2023, 11:32 PM
Pandelis Pandelis is offline
Exclamation Rieju MR300 piston end gap specs?
Hello
Anyone knows what is the actual piston end gap min and max spec? Could not find the Rieju workshop manual anywhere.
Gas gas manual states 0.5mm to 0.8mm
My old original S3 piston was 0.4mm
The new S3 piston that I am about to replace is 0.25mm
Nothing matches!
What do I do??
Thanks
Old 08-01-2023, 12:49 AM
SS109 SS109 is online now
Originally Posted by Pandelis View Post
What do I do??
Always follow the piston manufacturers specifications. See, different companies can use pistons/rings made of different alloys from one another hence leading to different specs for their particular piston and ring setups. Again, follow the instructions that are specific to the piston you're using.
Old 08-01-2023, 01:10 PM
Thanks, that's good to know.. But for next time!
I was in a bit of a hurry so I decided to file it down to 0.4mm same as the original piston i removed since it was the same brand (S3).
Unfortunately S3 didn't specify any specs or any range of gap clearances, which I think they should.
I assume that I am still within spec.
Old 08-02-2023, 06:39 AM
Noobi06 Noobi06 is offline
A good ring gap is usually 0.005"-0.007" per inch of bore.
Meaning if your bore is 72mm (2.83inches), you want to be inbetween
2.83 x 0.005: 0.014 inches: 0.35mm
2.83 x 0.007: 0.02inches: 0.51mm
You want to be inbetween 0.35mm - 0.51mm
Old 08-02-2023, 01:19 PM
Thank you, it nice of you to share this information. I will keep this notes for the future!
Tags
end gap, piston gap, ring, specs
rieju mr300 vs 17 ktm, are the counter balance engines worth the extra money abraham General Discussions & Announcements 5 03-29-2022 05:48 PM
Rieju MR300 reviews? SS109 General Discussions & Announcements 1 12-25-2020 10:16 AM
Rieju MR300 mitinsky General Discussions & Announcements 4 11-02-2020 09:30 AM
Gas gas ec450fse 2004 piston ring and piston pin for sale Laszlo ervin Parts 0 12-12-2019 08:26 AM
2014 250 Piston Specs? Blakelpd5 Enduro Engine - 2 stroke 0 05-06-2015 02:02 AM
