Old 07-31-2011, 03:12 PM
nambo-trev's Avatar
Default Rekluse exp install tips from the guys that know!
Hey guys just got my rekluse exp and want to know if there was anything you've encountered or found to be a bit of a pain in installation or in setup you would have done the first time around? I thought it would be worth asking to try and save the time others spent with figuring the quirks of the clutch out.any help would be great!
trevor
Old 07-31-2011, 03:20 PM
rgranger's Avatar
rgranger rgranger is offline
from my install on my ktm:
1) air impact.
2) lay over on left side, won't spill a drop of oil.
3) let you new plates soak for at least 6 hours.
4) don't lose any of the little balls or springs!
It is really pretty easy. make sure that you have the latest adjuster nut, should be silver and not anodized the same as the basket.
the directions are pretty good if I could manage without busting something.
Oh, watch out for your shift lever if laying over on the side, it may drag on the GG.
Rob Granger / Katy, TX EC300
Breaking more things by 8:00AM than most people break all day.
Old 07-31-2011, 09:34 PM
nambo-trev's Avatar
i dont see any little balls in the kit? also what is the easiest way to get the nut that holds the main hub in? is it impacted because it seems very difficult to get off?
trevor
Old 07-31-2011, 10:31 PM
rgranger's Avatar
Impact for the primary nut. A rag in the gear teeth works for take off but not so well for the back on, that is where the impact comes in handy.
Old 08-01-2011, 05:40 PM
nambo-trev's Avatar
ok so i got the clutch put in and set at 1 turn and 5 clicks and engagement feels exactly the same as my stock clutch, i didnt adjust anythin from the stock clutch and it feels perfect. a quick question though, since the clutch cover is a little bigger does everyone still use the same 900ml's of oil? wasnt sure if some run a little more volume or not.
trevor
Old 08-01-2011, 06:23 PM
2whlrcr 2whlrcr is offline
I been putting in a full quart. Quick and easy and seems to work just fine.
Old 08-01-2011, 08:20 PM
nambo-trev's Avatar
That's what I also was planning on doing, with a little more volume in the cover I thought 46ml's wouldnt hurt and I hate having all the spare bottles with a little left in each one!
trevor
Old 08-01-2011, 10:45 PM
rgranger's Avatar
I run a little more, but if you go by the sight window, you should be good as the larger side cover will just hold more oil to get to the same level.
Old 08-02-2011, 01:48 AM
Bikerdad450F Bikerdad450F is offline
Default EC300 EXP install too
My thoughts, Rekluse tech staff are great ! I am a mechanic and I still had questions for them. It was a question of "feel". When you are almost done the install, and you are threading in the aluminum adjuster "nut" with the allen key. The nut stops on the inner clutch hub Nut and then you make a mark. Then break in the clutch, then re-adjust the nut.
My issue was that the Gain (at the Lever) measurement was too much (3/8 inch) and I assumed I had to keep spinning the adjuster in, wrong, too much gain requires you to back off the adjuster, that was not clear enough for me in the manual. ended up going from 1 full turn PLUS 8 tics, back to 1 full turn plus 3 TICS. Works sooooo nice now. Make sure to check your gain before every ride. Just 1/8 " at the tip of the lever. any more or less and you could be doing damage/ slipping clutch with out knowing it.
Old 08-02-2011, 09:21 AM
rgranger's Avatar
Odd, my manual I think says after break-in the setting is one turn plus two or three ticks. maybe you had a odd revision of the install guide or maybe a smudge turning 3 into 8?
dyna ring install ? jhendr3702 General Discussions & Announcements 13 02-17-2011 03:29 PM
TuBliss users...New install tips to know!! Skidad General Discussions & Announcements 13 08-21-2010 08:15 PM
EC 200 set-up tips needed bondo General Discussions & Announcements 20 10-23-2007 01:15 PM
top end install help!!!! rdbandkab Enduro Engine - 2 stroke 12 01-19-2007 04:20 PM
Tech Article : Rekluse Auto Clutch Install webmaster Enduro Engine - 2 stroke 0 07-24-2006 10:14 PM
