Old 10-31-2020, 11:28 AM
Nero14 Nero14 is offline
Default EC300 Gearbox oil
Hi guys,
2014 GAS GAS EC300.
What type of oil should I use in my gearbox ?
Manual says to use "10W30 API SF o SG"
Will the mineral oil work fine?
https://www.motul.com/ca/en-US/products/transoil-10w-30
Or should I use the technosynthese one ?
https://www.motul.com/ca/en-US/produ...-expert-10w-40
Is there better oils out there ?
Thanks !
Old 10-31-2020, 07:39 PM
SS109 SS109 is offline
Standard oils are fine. Just make sure they have the correct rating that approves them for use in wet clutch applications.
That said, I always use ATF Type F transmission fluid.
Old 11-01-2020, 01:33 AM
In my experience Motul Transoil std makes the clutch drag.
Motul Transoil Expert allows you to kickstart in gear.
Lovely stuff.
Old 11-01-2020, 02:16 PM
belray gearsaver was my go-to. I once found some of the OEM GRO oil and that was as good if not better
Old 11-06-2020, 08:18 AM
Another vote for the Bel Ray Gearsaver. I use the W80.
Old 11-06-2020, 08:19 AM
I used to use ATF Dex II. Just out of interest do you know what the difference between the Type F and the Dex II is?
Old 11-06-2020, 09:24 AM
Type F has friction type material added to the oil.
Old 11-06-2020, 12:56 PM
The friction modifiers are different. The Type F has less friction reducing modifiers, which results in a more aggressive engagement, than the Dextron/Mercon II/III.
Old 11-08-2020, 02:31 PM
Thank you for your quick reply.
EC300 '07 gearbox complete/uncomplete. DawidPL "Wanted to Buy" & "Want To Trade" 0 08-12-2020 02:38 AM
Gearbox Oil About RomeoMustNotDie Enduro Engine - 2 stroke 23 03-08-2017 08:32 PM
Gearbox oil 10 40? Capz85 Enduro Engine - 2 stroke 4 05-24-2015 08:59 AM
ec300 gearbox stuart Enduro Engine - 2 stroke 1 03-14-2015 02:50 PM
bung beside gearbox drain bung 2002 ec300 andy176 Enduro Engine - 2 stroke 6 05-01-2013 09:05 PM
