Old 04-10-2015, 02:29 PM
bkoz bkoz is offline
Default Rear MC Seal Crossover Help
I am chasing poor rear brake performance on a friends '13 EC300. I am thinking that it needs a master cylinder rebuild.
The master cylinder looks very similar to some Japanese bikes. Does anyone know what rebuild kit would crossover?
Old 04-11-2015, 01:17 AM
Moto7man Moto7man is offline
Look on the mc for the name of the mfg. it's probably a Nissin. Also, check for a deformed bleed nipple on the caliper. Some people have had bad brake performance because the bleed nipple was deformed during installation at the factory.
―Comedian Lewis Black
-Unknown Sardaukar
Old 04-11-2015, 09:08 AM
barossi73's Avatar
bad performance in what way?check the brake lever is set right and not just hitting the stops a fraction early.obviously if its miles out it will clunk but if its only just hittin it wont unless you stamp it.theres not a lot of room for the required travel if you lower the pedal on the 13.also check caliper is sliding/floating freely and disc is not slightly warped/bent.this throws the pads further apart and requires more pedal travel to actuate.cracks allowing pad material to lift slightly can also cause this and a spongy feel.if the seals are shot youl most likely get some weeping at the rubber boot under res.give it a good squeeze to check.also flip the caliper and look closely for weeping around the piston boot,press piston in a little to confirm its not ceased.will be stiff but not rock hard
also have a look behind the chassis rail where the lever goes behind it for trail trash.i had some shrubbery get caught in there,was almost invisible but was just enough to prevent/dampen the last bit of travel that locks up the rear
2013 ec200r
Old 04-13-2015, 09:40 AM
Pedal is brand new. The brake has a mushy feel even after bleeding via a Mityvac. Prior experience says that it feels like a a bad MC piston seal. No external leaks.
Old 04-14-2015, 04:54 PM
2taddict 2taddict is offline
If Nissin check kit part no's against crf450x. My 05 looks exactly the same as 07 Honda
Brake seal kit crossover? nick790 Enduro Chassis & Body 4 04-04-2015 09:15 PM
rear sprocket crossover BSM2 Enduro Chassis & Body 3 03-19-2015 03:03 AM
Rear Sprocket crossover lankydoug Enduro Chassis & Body 13 11-04-2010 02:55 AM
Rear wheel seal question. Ud_luz Enduro Chassis & Body 0 09-07-2010 06:55 AM
rear spokes crossover??? kendunn Enduro Chassis & Body 1 11-24-2009 12:19 PM
