Old 04-14-2019, 05:59 AM
Booki Booki is offline
Default 2018+ Front Fork Guard Rubbing issue
I have a 2018 EC300 and it has been pointed out to me that there is an issue with the front fork guards rubbing against the forks.
This may go unnoticed for quite some time, so please check your forks closely near the clip. I have 300km on my bike and the clip has some wear on it.
One of the facebook groups I am a member of brought this to my attention and Sean has made up some protectors.
https://www.facebook.com/seangriff
Just thought I would bring this up for other users before its too late!
Old 04-14-2019, 04:28 PM
Being kyb you could also get some of the mud scrapers from skf to do the same (for those not based off n the UK) (or just keep an eye on it- the steel clip is there as a wear item)
Old 04-14-2019, 07:35 PM
Yes.. it's not just a KYB issue either.
Zip ties cost less than new clips, and much less than SKF.
Old 04-14-2019, 09:38 PM
From a quick look, the steel clip do anything other then provide a buffer from the fork guard...So yes, I guess a zip tie would be fine if you remove the clip?
Old 04-15-2019, 12:18 AM
shawbagga's Avatar
Nah mate ya just run a thick zip tie above the clip.
'18 Gasgas XC250
Old 04-22-2019, 08:48 PM
rvktm rvktm is offline
the wp 48 plastic bush / sleeve fits kyb and marzocchi 48 mm i used a heat gun to get them on only about a fiver uk for two from ktm
2018 XC - diagnosing electrical issue GG221 Enduro Electrical & Wiring 13 03-14-2019 07:53 PM
2018 ec 300 power valve issue Sterlo300 Enduro Engine - 2 stroke 8 10-27-2018 08:46 AM
What fork guard & front fender??? Zrt1200 Enduro Chassis & Body 5 08-15-2016 08:57 AM
coating rubbing off fork tubes swazi_matt Enduro Suspension 16 04-26-2012 12:53 AM
43mm Fork issue !!!!HELP!!!!! Wicitup Enduro Suspension 12 03-30-2012 10:22 AM
