Old 03-30-2020, 02:07 PM
hannesd hannesd is offline
Default battery relocation
hi,
i've got a 2015 ec200 with the battery located i the seat.
this is a hassle when changing the airfilter.
has anyone already found a better location for a battery?
thanks, hannes.
Old 03-30-2020, 03:23 PM
Originally Posted by hannesd View Post
hi,
thanks, hannes.
I fit up a big Anderson style plug to the battery leads so you can lift the seat and remove the battery/seat combo and change the filter a little easier.
Old 03-31-2020, 07:02 AM
sounds like a great sollution, i'll see what i can find locally,thanks
Old 03-31-2020, 12:06 PM
Something like this would work.
https://www.amazon.com/HYCLAT-Batter...05&sr=8-6&th=1
Old 03-31-2020, 02:00 PM
since there is no other place to fit (a full size) battery, i'll go for the suggested sollution.
i don't want to install li-ion battery, because of the procedure to warm up the bike... altough,thinking about it, my previous bike (sherco 300 SE) didn't have a kicker, so it had to work every time, now i could startup with the kicker and when needed (once warm) i could use the starter.
anyone have experiences with smaller size li-ion batteries? and not the +- 100? batteries.
Old 03-31-2020, 04:58 PM
On my '18 I have an Anti Gravity 240cca Lithium battery.
I have never needed to do special cold start procedures.
Doesn't even need recharging.
Coolant Surge Tank Relocation? grachal Enduro Engine - 2 stroke 5 06-10-2019 04:37 PM
Bike won't run without battery and won't charge battery memphis2857 Enduro Electrical & Wiring 3 04-28-2017 09:02 PM
12 battery box shark4465 Enduro Chassis & Body 2 11-09-2012 04:45 AM
Battery for a 07 450? fastisbetter Enduro Electrical & Wiring 2 03-29-2011 08:06 PM
MAP switch relocation? husley General Discussions & Announcements 9 01-17-2011 08:06 AM
