Old 11-17-2015, 01:44 PM
MNKeith MNKeith is offline
Default Losing feel in front brake
Confused.
I have an '08 EC250 with a front brake that has a mind of it's own. When cold, I have normal lever feel. After a brief amount of riding, the lever travel shortens dramatically and is quite stiff. The front brake still operates but I lose leverage with the shortened pull and the feel just isn't very good. It doesn't seem to return to what I deem normal until the bike has been put away for the day.
This problem has been the same through:
Various brands and flushes of fluid.
Varying amounts of fluid in the master (from bottom of sight glass to top)
Multiple brake pads
And now on a brand new front brake line (replaced due to wear)
Now I'm on to either the caliper or the master? Or something I'm not thinking of. Any experience or thoughts on this?
-Keith
'08 EC250 and some other bikes.
Old 11-17-2015, 02:21 PM
Take the caliper apart and rebuild/clean it. It's probably all cruddy and when it gets hot the tolerances in moving parts gets tighter and it gets sticky.....maybe?
Old 11-17-2015, 04:03 PM
Rick's Avatar
Rick Rick is offline
Try putting a zip tie on the lever and throttle grip, pull it tight with a good amount of pressure. If there is a bubble it will work it's way back to the master cylinder... I'd try this first....could be an air issue.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 11-17-2015, 04:16 PM
twowheels's Avatar
I would have thought the same if it got spongy when riding, but not the other way around. Rebuilding the slave and master seem like good routes to follow.
Steven Beane #275
afterhourscycle.com
Old 11-17-2015, 06:09 PM
I'm very confident it's not an air issue.
I'll dig into the caliper first and see what I find. Gotta take that off this week for some unrelated maintenance anyways.
-Keith
Old 11-17-2015, 08:34 PM
Check the slide pins on the caliper. They may be binding when hot.
Old 11-17-2015, 11:04 PM
Well I diverted my night of working on the bathroom project to work on the bike a little instead. More fun.
Took the caliper apart. Gave the pistons a light sand and greased up the slide pins. No obvious issues anywhere. The lever does feel a little better now but that could also be some placebo going on.
Might leave it alone and see how it is when I ride it next week.
-Keith
Old 11-18-2015, 05:35 AM
RBrider's Avatar
RBrider RBrider is offline
I had this same problem with my '01 200 with Nissin brakes.
Check the tiny bleed hole in the bottom of the master cyl reservoir. Run a tiny strand of copper wire thru it to make sure it is clean and 100% open.
RB
Old 11-18-2015, 10:50 AM
RB
ooh. Will do, thanks!!
-Keith
Old 11-18-2015, 12:35 PM
Moto7man Moto7man is offline
Check and replace the bleed nipple on the caliper, someone else had the same problem and the bleed nipple was deformed. He had the same inconsistent braking problem that you are having and it actually caused him to crash and get hurt. Then he traced the problem to the deformed nipple, he replaced it and braking problem solved.
―Comedian Lewis Black
-Unknown Sardaukar
Tags
front brake
RHS Crank seal, losing gearbox oil krazy Enduro Engine - 2 stroke 8 08-19-2015 03:50 AM
Front Brake Mod GasGas Enduro Chassis & Body 3 09-19-2013 06:33 PM
EC300 losing power + rattle (F5) Enduro Engine - 2 stroke 32 08-13-2012 12:36 AM
forks feel sticky hannesd Enduro Suspension 10 07-05-2011 09:07 AM
losing coolant Gassey fan Enduro Engine - 2 stroke 3 02-24-2010 12:18 AM
