#11
I have them too on Excell rim without any problems, but a firend used them on DID round shoulder rims and he looses the air pressure over 2 days.
I found out that when a litle bending is in the rim, you will not get them sealed.
4 strokes are only good for power generators |
#12
Did you remove the nut from the high pressure tube...I couldn't get a good seal around the inner tube valve stem until I removed the nut...I use a tire sealant as well...no issues for the past year.
#13
you talking about the nut at the base of the valve? If so i believe that must stay there or you run the chance of tearing the tube around the valve. The first versions didn't have the nut and i have experienced this tear
#14
Because it gets so nasty here (weather wise) I'm usually at 3-4 psi on the rear. I just finished the Manua Kea 200 race, with no issues and have had no issues since I purchased the Tubliss more than a year ago. I also change and/or flip tires about every month or two depending on wear, I don't let the tires get too worn out. |
#15
The new ones have a thick rubber pad on the inside and the small knurled nut on the outside of the HP tube valve. It shouldn't matter what tire or tire pressure you run, the inner tube should not move. Also, the newer ones have a rubber spacer under the rimlock in place of the old metal one. I wanted to update mine, and asked Jeff if I could purchase a couple as I did not see them on the sites store with the other spares. He sent them out the next day for free. What a great company.
Congrats on your Mauna Kea finish! |
#16
I raced the "B" masters class and won 1st place in class....and first overall in the entire "B" class. I had the lowest score out of all "A" class and "B" class riders. So, got moved to "A" class. Great to smoke all those new KTM's with my 08 GG |
#17
I would think so, being you actually won the A class from B. Awesome, thats some tough terrain. Been to the island and area but never rode there, just in Kauai.
#18
he got it fixed... the slime trick did it.. we had a great ride today..
5 riders... 2 gg's... 2 yamahas( one was a 1987 yz250.. old school nice bike) and one pumkin.. great times..
broken down over 60 slow rider.. |
aftermarket rims | Moto-x | Enduro Chassis & Body | 4 | 01-27-2012 04:10 PM |
120/100-18 on 2.15 rims? | gasIdaho | Enduro Chassis & Body | 5 | 04-24-2007 08:21 PM |
94' rims | Elvis74 | General Discussions & Announcements | 1 | 03-25-2007 09:50 AM |
D.I.D vs. Excel rims. | ktmbigfan | Enduro Chassis & Body | 4 | 02-22-2007 09:20 PM |
