I had a rich bottom end and doing searches I came across the solutions below. The slide change worked for me, cleaned up the whole bottom end, couldn't even get it to idle for very long with a 35 pilot and air screw nearly 4 turns outs. With an 8 slide I had to increase to a 38 pilot and have the air screw at +/- 1-1/4 turns out, idles all day long
i know it was a bit silly to try a 5 plug but in search of a solution..it did not even rev properly anyway.the slide is probably the last thing i did not try. the mix is good the octane is ok since i add octane booster and the base gasket is a standard .25 mm. in the caribbean it is not easy to machine the cylinder head but i don't think it is that bad for a new bike my 250 had the original plug for 5 years and works like a champ.
300 racing 2009 300 Factory replica 2014 250 XC 2018 SWM 250 TF1 1981 TXT 250 2003 |
ec300 fouling plugs after jetting | ec300 dave | Enduro Intake/Carburetion - 2 stroke | 14 | 05-25-2010 07:32 AM |
i keep fouling spark plugs??? | tom-s | Enduro Engine - 2 stroke | 7 | 08-28-2009 01:37 AM |
gasser 250 splutering and fouling plugs | gasser250sm | Enduro Intake/Carburetion - 2 stroke | 0 | 12-01-2008 06:50 AM |
Fouling plugs | rupecopp | Enduro Intake/Carburetion - 2 stroke | 3 | 08-11-2007 03:43 PM |
Plug fouling | wheels244 | Enduro Engine - 2 stroke | 13 | 05-13-2007 03:48 PM |
