Old 05-04-2010, 05:52 PM
HuskyDude's Avatar
Default Ok here's one for ya.
It's been brought to my attention (Thx Rod) that on the bottom of the engine case (EC300) between the oil drain plug and the crank drain plug is another threaded hole in the case. It has no bolt in it. I'm assuming in must be a drain hole but not sure...
This is looking through the skid plate while standing on my head. sorta upside down picture.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 05-04-2010, 06:52 PM
It's a mounting hole for the assembly line jigs when they are building the engines.
Old 05-04-2010, 07:00 PM
HuskyDude's Avatar
Thank you.
Does it need to be plugged or is it a blind hole? I guess I could go out and stick something in it to see how deep it is...
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 05-04-2010, 07:52 PM
jostby jostby is offline
isn't that also a "drain" or vent for the ignition/flywheel area? I think it is drilled through to that area.
'00 XC250 (mine)
'04 EC250 (the kids)
Old 05-04-2010, 09:27 PM
roostafish's Avatar
Yes indeed. That hole vents into the ignition area. I was always torn as to what to do with it. Leaving it open lets any water that gets under the cover to drain out. Plugging it traps water if your gasket leaks, which is pretty common (not just to Gas Gas). I kind of liked the idea of leaving it open, but I still take the cover off and douche it out with WD 40 now and again.
The paranoia in me keeps me doing this. I had a KTM 125 once that trapped water under it and rusted all the steel parts, the ensuing carnage was a blown crank seal and a lunched bottom end.
Mike Sheetz
OMRA #21AA
'15 KTM 300 XC-W
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 05-05-2010, 06:08 AM
HuskyDude's Avatar
Thx everyone...and that is why I love this place...ask...and ya get answers.
HuskyDude
10 EC300XC
08 TE510
07 TXT 280
77 TY175
Old 05-05-2010, 09:02 AM
nick790's Avatar
nick790 nick790 is offline
I was told it's a port hole to a parallel universe, everyone rides Gasser's, apart for some strange sorts that ride KTM's. And there's a good looking version of me that rides pro level enduro.
Of course that could be wrong, but I'd plug it up just incase!
Old 05-05-2010, 09:12 AM
dgstandard's Avatar
dgstandard dgstandard is offline
Default Maybe
Could you stuff some foam or mesh in there? Is there a "one-way" plug around?
2010 EC300 Nambotin
Old 05-05-2010, 09:18 AM
dank's Avatar
dank dank is offline
it seems strange to me that they would make a vent hole where water can get into the ignition area. i would think that you would plug it, and take it apart regularly to clean out anything that does get inside. or maybe put a tap and hose in it and run the hose back so that it would be harder to get water into. dunno, just doesnt seem like a good idea to put a vent there.
03 ec250
hyde skidplate, cycra handguads, protaper contours
"what? it seemed like a good idea at the time!"
Old 05-05-2010, 11:40 AM
jefgil123's Avatar
jefgil123 jefgil123 is offline
One of the shops in Australia made some 6mm Vent screws for the front
gas tank mount, your cap vent line can fit on it.
You could use one of these to put a vent line on. Plug it just before a ride,
then unplug after....
