Old 06-14-2015, 05:00 PM
gasser's Avatar
gasser gasser is offline
Originally Posted by Jacob 'Berg View Post
Too true Rod, I would not exchange our hottest days here (118+) for 95+ and 80 percent + humidity. Been there done that.
Spent several summers in the Middle East and the worst days weren't those that were 120-124 degrees because they were windy and dry. Going outside was like using a hair dryer. Much worse was the 110 -115 degree days with no wind but 90% humidity. At one location we never saw an August temp lower than 110 for the daily high or lower than 87 for the nightly low. We did get a little extra money for combat pay there but nothing extra for working 24 hours a day 7 days a week.
Old 06-14-2015, 07:44 PM
jimjim jimjim is offline
Bleed my clutch,make sure the plunger is not touching the lever.
Old 06-14-2015, 08:33 PM
Terrence R Terrence R is offline
I put white spoke wraps on my front wheel. I'll be doing the rear tomorrow.
Old 06-14-2015, 10:21 PM
fst96se fst96se is offline
please post pics when you're done! What year is your bike?
Old 06-15-2015, 12:53 AM
Rick's Avatar
Rick Rick is offline
I surely remember those days in Saudi Arabia, Kuwait, Jordan very hot 120+. Nothing can compare to the Horn of Africa or being in Eritrea in August! Down right brutal!!!
Oh......did nothing to the GasGas, applied a little WD40 to the pipe....gotta keep the rust off!
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 06-22-2015, 01:26 AM
Gas Gassin's Avatar
Gas Gassin Gas Gassin is offline
I have an 2004 Ec300 motor and pulled the clutch basket and clutch boss out and filed them both down took awhile. Had my new moose clutch plates in an oil bath for 2 days. Reinstalled clutch basket and clutch boss new friction plates and the old steels put all the rest back used torque wrench filled with fresh AMSOIL. Kick started it, warmed it up. Clutch was working great I fixed my stuck clutch rode it for a min in my HOA then back to the bat cave. Rides like a champ.
NOW I CAN NEVER REST!!
Old 06-23-2015, 02:21 PM
VxZeroKnots's Avatar
VxZeroKnots VxZeroKnots is offline
Drown it pretty good last night riding in the woods to the west of town.
Drained it from the crankcase and pulled the plug and flipped er over. Wrung out the air filter and she cranked back up. Rode ~10miles back to the truck so I'm hoping that evaporated any remaining water.
Ran fine on the way home and the creek water was clear and fast so I'm not too worried about silt. Time will tell I guess but any damage is likely done at this point.
All in all it was a good ride though!
Old 06-23-2015, 05:42 PM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
Unless your skid plate blocks access to it, your GasGas enduro bike will have a drain right under the crankshaft area, that is made for situations like yours. You don't have to pull the spark plug and turn the bike upside down. Just pull the drain plug out of the bottom and let/blow (pump with the kickstart lever) the water out of the bottom of the crankshaft area.
This drain plug is located forward of the transmission drain plug and the 6mm hole that vents the ignition, right under the crankshaft.
I'm glad everything came out okay for you.
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 06-23-2015, 07:35 PM
Selvagem Selvagem is offline
At the end of last week I installed the Kick Starter YZ 250, actually much better than the OEM.
GasGas EC 250 2008
Equipped KYB SSS Fork.
Old 06-23-2015, 08:32 PM
Skid plate was blocking it but I ended up pulling it anyway just to be sure all the water got out.
DNF today Pepperami Enduro Chassis & Body 6 09-18-2013 11:59 AM
Got my first GG today! RonMexico General Discussions & Announcements 6 02-19-2011 12:39 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
HELP! I tried to use my gasgas as a jet ski today! sammyj18 General Discussions & Announcements 19 11-21-2008 08:01 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
