Old 08-01-2006, 10:41 AM
Mark Tracy Mark Tracy is offline
Default My 50 Year Old Birthday Present - Sept 2006
I think I got the semi-green light to buy a new bike in September from my wife. Currently I am riding a 2005 KTM 300 EXC which is a fine machine and a pretty decent standard to base my new bike choice on. I have pretty much zero'd in on a 2007 GG 300. That said the discussions on 2 strokes and their future is a bit perplexing. I would buy a 300 to 350 4 stroke with little hesitation, however none exist. The new KTM 250 EXC-F has been getting great reviews, but I just don't want to "scream" a 250F. That said a 300 - 350 bore/stroker kit adds another $1500 -$ 3000 depending on who you talk to and has not been proven reliable to my knowledge. Below is a GG works bike comparison against my KTM as my work sheet and hopefully for your amusement. "+" means positive, "-" negative, and >> general stuff. Feel free to comment, as I value this forums input.
+ Nice full length plastic frame guards
+ Incorporated rear brake reservoir - Nissan!
+ Folding break pedal tip
+ Olins rear shock!
+ On the fly ignition map switch (sun and rain mode)
+ Master link kickstand spring - believe it or not, I was the originator of that back in 99
+ Like the braking SOLID rear rotor (the one off my KTM will fit a GG and is like new)
+ Very cool , our own GP's, GP radiator braces
+ Very thin ergo and tank (KTM not too good here IMO)
+ Yes, I agree the adjustable PV is very, very cool (my KTM has a screw and alternate spring replacement adjust that makes a huge difference in the power output - that said the G2 Ergo throttle kind of does the same thing and wil retrofit off my KTM to a GG).
+ YEAH!!! No Torx head screws on the kick starter
+ Extra Radiator length added?
- Same break pivot bolt bushing with single capture on the frame - KTM far superior with 2 ball bearings and 2 sided capture
- Soft foot pegs??? No stainless? - one works bike has nice CNC pegs ---- Pivot Pegz for me
- Sorry I hate that antique chain guard, my EC 300 hit a root and bent all the way forward some how - also I see wear on the nylon - KTM with the aluminum chain cage removed or TM works wins here. I think the 07 have a true plastic?
- Black painted Olin forks (you can see the paint wear and the gold Olins)
- The age old question - are the Olins really better than the new Marzochi forks??? Factory riders think so
- No zerk fittings on the shock like - Husqvarna has a really nice zerk setup on the linkage
- I hated rebuilding the linkage on the GG and the porr sealing system
> NO STEERING DAMPENER on the factory bikes??? I think Eric has something going with the tighter Steering Stem Bearing. I think it would be best for me not to fit a dampener on - at leats until the suspension is tunned.
> The rear break P clip or cotter pin has me baffled - I thought it was a threaded Allen head? KTM wins hear with 2 simple "P" clips...
> Do you really need an in line radiator cooler? Logically it would help.
> Painted black swing arm - I like the natural
> I prefer Ironman sprocket over a Tri-metal Sidewinder
> I see the silicone in the shift tip - I did this to keep the pivot rivet from elongating the shifter attach point due to vibration/mud --- it will still bend back if hit
> The torsion spring on the chain adjuster ???
TeX MarK
Old 08-01-2006, 01:38 PM
Eric K Eric K is offline
Mark,
Take that green light and GO! Good luck!
More input, GasGas compared to KTM...
+ Shiver forks do an awesome job for me. They are far better than WP.
+ versatility and performance of the linkage suspension with the Ohlins shock.
+ outstanding GasGas handling, cornering and stability.
- Soft foot pegs - Get the real pegs you want.
- Chain guard - Get an LTR chain guide and go ride.
- I hated rebuilding the linkage on the GG and the porr(sp?) sealing system - I also hate the rebuilding the linkage. The new seals are much better. Keys to longevity and avoiding rebuilds... Use a good moly grease when new. Periodically regrease. Don't directly pressure wash or hose down the linkage bearings or swingarm bearings. Don't get solvents or fuel on or near the bearings as they quickly wash out the grease.
> NO STEERING DAMPENER on the factory bikes - Keep in mind the GasGas is inherently more stable. I suggest that you first tighten up the Steering Stem Bearing and see how it works. If that doesn't work for you, then go spend your money on a damper.
> Do you really need an in line radiator cooler - The GasGas 2 stroke is very tough to overheat. If you run really slow, hard climbs you may be prone to overheating. My solution is to use Evans waterless coolant. I haven't lost a drop of coolant in the gnarliest, low speed climbs on hot days.
> I prefer Ironman sprocket over a Tri-metal Sidewinder. - Ironman is far superior. My conclusion was clearly influenced by a very poor quality Tri-metal sprocket with soft teeth.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 08-01-2006, 01:59 PM
jeffd jeffd is offline
Hey Mark,
Wow, I had no idea you were so... um... well... mature.
I don't think you need to worry about the black swingarm. I think that is one of the magnesium swingarms that the factory rider's use to drop a few pounds off the bike. These are checked out to the factory riders - I don't think the average guy could get one at any price - and if you could get one, I don't think you would mind it being black!
BTW - the evans coolant doesn't boil and doesn't expand - but it doesn't transfer heat as well as water either... You can run a lower pressure cap and it does make the cooling system less prone to failure. However, the engine temp may be hotter when running evans and it wouldn't be apparent to you.
Old 08-01-2006, 05:59 PM
Evans coolant does expand quite a bit. Adequate expansion space needs to be provided.
Evans coolant will boil at high temps (375F for NPG+ and 400F for NPGR).
With Evans coolant, the engine temp will run a slightly hotter under normal operation. Where Evans works much better than conventional coolants is when you get hot enough to boil conventional coolants and create steam pockets. The steam pockets act like insulators and reduce cooling system heat transfer. Evans coolant remains a liquid at the high temps continuing to provide effective liquid cooling.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 08-01-2006, 07:21 PM
MattR's Avatar
MattR MattR is offline
Mark,
How does it feel to be half a century old? ha, ha... just joking.
I noticed your comparison was referring to the GasGas works bikes. Are you planning on buying one of the bikes Berkyboy is selling? I think the GasGas team would strip off some of those mods (like the magnesium swingarm). You will love a GG 300 (either works or plain-jane setup). GasGas makes the best 2-strokes! You won't regret it.
Matt
Current: 2009 Yamaha FZ1
Old 08-01-2006, 07:32 PM
Mark had a GG 300............But,you know the "herd" mentality?
Actually, Mark is celebrating the 24th anniversary of his 26th birthday.
Old 08-02-2006, 10:15 AM
JTT JTT is offline
Hey Mark, for what it's worth the linkage seals must have improved drastically since you had your 300. I can from Japanese bikes and the linkage on my 2003 is virtually maintenance free compared to my old Hondas. I haven't had to live with a linkageless PDS system...but hopefully never have to
Old 08-03-2006, 01:58 PM
Original linkage parts on my '03. This season I replaced the seals with the orings used on the newer bikes, they seal tighter than the seals.
I rode a friends KTM300 two weeks ago. Its been awhile and I was reminded how crappy they feel in the rocks.
The Evans is great stuff for a 4-stroke, its one of the first things I would do. Made my Cannondale ridable in the woods. It makes the engine run a little hotter, but the key is no hot spots, as Eric explaned. The 'Dale's ECM would shut the bike off if the head temp got too hot, and that never happened, even on multiple attempts of steep climbs. All components run approx the same temp, and the system pressure is very low. When you boil conventional coolant, you boil it in the motor, not the radiator, creating gas pockets and hot spots. This is more dangerous than a slightly higher even temperature. On the 2-stroke its not neccessary, IMO. I've had no issues at all with either standard coolant mix with Water Wetter, or Engine Ice. Just run a 1.4 bar KTM cap, even 50/50 coolant/water with no additives should be fine.
Old 08-03-2006, 02:02 PM
Thanks for the upbeat and positive comments!!!
Yep, it is quite surprising even to me I am turning 50 - I've been riding dirt bikes since I was 13. Off road riding keeps you young, is a great workout, really minimizes stress, which we all have, and -still- is a great deal of fun. I figure I can gat a slight advantage in the over 50 B class :0 -maybe -, some of those guys are still rockets, you have seen them.
The linkageless KTM has been quite maintenance free with a decent pivot works bearing, I am glad to hear about the 'O' ring seal as those cupped seals were not the greatest. Way back when on the Smackover forum adding zerk fitting was discussd, a la Husqvarna, and was tried with little success, likely the same holds true now. I really believe in the zerks as my Husky linkage looked new after 6 months of riding - I just greased it after every wash - nice.
Totally agree, the sweet Gas Gas handling, ergo, etc. that is why a 07 300 is on the top of my list - Dirt' Rider's Jimmy Lewis ran one in the Ensburg (sp?) torture race, but it was a 250, that says a lot IMO.
I really am not concerned with over heating a GG, especially with the overflow tank. In the hottest Texas summers I never over heated my EC250, XC 300, or the 300 EXC - only that dang RMX. I run Moose Juice or what-ever.
A works bike would be cool, but I'll stick with an 07 production version, beside I want some of the fun modifying the bike .
IMO, the swing arm is not magnesium, perhaps it is? The special edition GG Trails bike do have a "mag" swing arm and a very special coating. I work with die casted mag parts for my occupation, and I am a bit leery about it on a swing arm. The reason being just last week end my KTM swing arm was submerged in a creek - as I pushed it up I watched water stream out of the drain holes (I drilled them in , they are now stock on KTM's) at the back base of the swingarm. Magnesium is a less noble material on the galvanic corrosion scale, and I would be concerned with durability and corrosion, but then again it would be a 1/3 lighter and I just may be over reactive.
The Shiver forks were on my TE 250 Husky - they were OK, then Les at LTR valved them and they were nice. Les also did my WP forks on my KTM and they are better than the Shiver IMO, but I do have some air cells (they get taken off before the KTM is sold) so maybe that's the reason. The Shiver forks on the TE did not have the coating - the newer versions are likely better.
Foot pegs will be Pivot Pegz - see product reviews.
Later,
TeX MarK
Old 08-04-2006, 10:00 PM
tm_enduro's Avatar
tm_enduro tm_enduro is offline
BUT, there are a few Husaberg fe380's running around. Husaberg offers a 380cc piston and sleeve kit for the fe450 to make a easier to ride bike, I don't know the cost.
Year By Year Comparison for 300 ?? GasGasDreamer General Discussions & Announcements 21 05-31-2011 10:53 PM
Happy Birthday Rick General Discussions & Announcements 11 11-13-2009 06:04 PM
Ammonoosuc Turkey Run, Sept 12, 13 nhrider NorthEast United States 19 09-18-2009 09:01 AM
450 FSE / FSR year changes iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 6 02-23-2009 12:26 PM
Birthday shout! Mark Berg - CPD General Discussions & Announcements 2 07-25-2008 07:04 PM
