Old 12-10-2013, 10:22 AM
nambo-trev's Avatar
That's funny cause I used the relay cable as my ground because it was a little longer. That's weird though because it's all just "wire"!
trevor
Old 12-10-2013, 10:47 AM
Diggs345's Avatar
Diggs345 Diggs345 is offline
My ground goes to battery - , +from battery to relay then out to starter , red and black / white to kill switch/ start button
Old 12-10-2013, 11:04 AM
Diggs345's Avatar
The blue cable is power in from battery
Old 12-10-2013, 11:13 AM
nambo-trev's Avatar
Yup that's what I got right now , thanks for the pic bro!
trevor
Old 12-10-2013, 11:27 AM
nambo-trev's Avatar
So the white green and red out of harness that plug in, the green is ground and the white goes to the start button and what is the red for? Just wondering which spade connectors on relay do what?
trevor
Old 12-10-2013, 11:40 AM
pscook's Avatar
pscook pscook is offline
The red should be hot (switched) from the ignition switch (looking at manual). It should have 12 volts when the key is on, the white wire is the "trigger" for the solenoid. Well, in my estimation, of course.
Also, put the ground wire right on the top of the starter motor. Much better to have direct to the motor than having the ground route through the engine cases. Just my opinion, but it removes variables.
Phil
(New bike pending...)
Old 12-10-2013, 11:42 AM
Diggs345's Avatar
White/black is connected to the red via the start button , or as I found out first if I shorted them together the starter worked
Old 12-10-2013, 12:02 PM
nambo-trev's Avatar
Oh boy what keyswitch?? Am I suppose to have a ignition key switch?
trevor
Old 12-10-2013, 12:19 PM
Diggs345's Avatar
I don't , the used kit I got had a yamaha kill switch for the starter
Old 12-10-2013, 12:33 PM
nambo-trev's Avatar
Default Where does this go?
Maybe there is a splice that has to go where the keyswitch should go as a bypass for ignition power to start button. I gotta find a schematic. This makes perfect sense though because without the key switch you could kill your battery with the light being left on. I'm going to try this first tonight and see if that solves the problem
trevor
