Clutch covers and part numbers, witch years fit witch ?
I'm in the market for a new clutch cover. The manual states that the part number i'm looking for '14 is ME22010GG.
Seller A states that the same part number fits '12 to '15. It also states that ME250732002 will fit 96 to '11. It also states the different part numbers for the '14 and '15 models are because of a new alloy used, but the shape did not change. It also states that the clutch cover gasket ME22015GG will fit '00 to '15 models. Seller B states that ME250732002, ME15000003011, ME250332002, ME25632002 and MFS450732002 will fit 96 to '13. It lists separately the ME22010GG for the '14 model (that i'm after, and does not have one in stock). Seller C states that ME22010GG, ME15000003011, ME250332002 fit each other. Who is right and who is wrong ? Because the overlapping '11 do '13 years means the same clutch cover will fit 96 yo '15 and that is hard to believe.
'14 EC300 |
I ride a 12 250 and found a used rekluse cover on ebay for cheap. Not sure the part#, but u might research that option. My stock cover was a leaky bastard.
p.s. prices for the above mentioned sellers are not that high tough, they range between 40 and 50 euros brand new
'14 EC300 |
Sorry don't remember details on it. I'll try and find out.
This is a very very messy job.
The Rekluse part number for the cover listed on gasgasmotos.es site, is ME650203013. They also state that it will fit EC300 from '00 till '15. So if the same Rekluse cover fits '00 to '15, that means '13 original cover should fit '14 model right ?
'14 EC300 |
I know 12-15 will fit. 12 cover was plastic and prone to leaks.
13 cover didn't have good splash oil direction. 14-15 cover would be my choice, but the older covers would work in a pinch.
15 GASGAS EC 250 19 Sherco SE 125R |
The one on stock i found in Spain fits 01 to 13, and made of aluminium. So based on your info, if it fits 12 and 13 it should also fit 14 and 15 right ? Thanks, this is great news
'14 EC300 |
I have a brand new plastic one that you can have very cheap if that has any interest. I am in Norway.
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
Thanks
'14 EC300 |
Part Numbers | 12Bravo | Enduro Other... | 4 | 10-25-2015 06:29 AM |
NEDW and NEDJ part numbers and measurements thanks | Stevel | Enduro Intake/Carburetion - 2 stroke | 4 | 04-10-2015 03:36 AM |
Nissin Brake Pad Part Numbers 2011 | Moto7man | Enduro Chassis & Body | 6 | 01-19-2014 05:40 PM |
Witch Spring.... | Packman | Enduro Suspension | 1 | 06-07-2013 01:15 PM |
need main bearing part numbers | mxdj2003 | Enduro Engine - 2 stroke | 0 | 03-15-2010 05:07 PM |
