Dual Map switch..
Have a 2005 ec300 in uk...have fitted a switch to my bars connected to the wires from the cdi unit...which I am told adjusts the powercurve..
Q. Have has it on the bike now for about a 12month, but cant seem to see any difference..Tested switch and one position current flows, the other position no current....How does this switch/current flow work ? How much difference should I be seeing/noticing ? WHat do you lads think of your swithes ??? |
I have an 07 EC300 and it has a switch. The only time you notice it is when it is jetted correctly and you are low in the revs and accelerating. It is a fair bit snappier off the bottom and when you blip the throttle on the sun mode.
Cheers Mark |
I have an 06 ec300 the snow/mud setting just seems to hold the bike out of the Power band for a little longer...
Gerald H 2006 EC 300 Recently UPGRADED from WR400F |
Cheers Gents,
I think Ive at last seen the difference today, as mentioned in both the above replies... |
Seriously contemplating switch. | REVERUP | General Discussions & Announcements | 11 | 11-14-2009 06:35 PM |
Dual mapping switch on 05 de250 | thelonius | General Discussions & Announcements | 3 | 06-01-2009 02:37 PM |
Dual Map Switch on Ec2008 | GG27 | Enduro Electrical & Wiring | 9 | 11-07-2008 07:43 AM |
dual ignition switch | ktmguy23 | Enduro Electrical & Wiring | 1 | 09-11-2007 05:21 PM |
