Old 06-22-2008, 03:57 PM
SeanUK SeanUK is offline
Default Starting problem
Hi
Just done an enduro on my 2005 EC & was having problems starting when hot. Found the headlight was switched on, it started fine when this was switched off. The obvious cure is not to have the headlight switched on but I didn't know if this was a sign of an underlying problem, or is this just normal?
Any help is appreciated.
Old 06-22-2008, 04:08 PM
mountain thumper's Avatar
mountain thumper mountain thumper is offline
is it a factory light, or aftermarket, and has the stator been changed?
could be that you have a light(bulb) that is is rated a little too high, it might be sucking juice from your ignition. i noticed when i hooked up my lights it has a little bit weaker spark, takes longer to warm up, although it never seemed to make it hard to start. i have a 35 watt stator, and 45 watts worth of lights!
Le Crutan
98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD)
FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck:
Old 06-25-2008, 12:29 PM
Thanks mountain thumper its all standard lights and stator .It was very wet and muddy typical summer weather here. I'm out this weekend going to try a new plug and cap first and disconnect the head light and see how it goes
Hot starting. nick790 Enduro Intake/Carburetion - 2 stroke 0 04-21-2010 02:44 PM
GasGas starting problem/ New member Anders from Sweden General Discussions & Announcements 7 06-11-2007 09:58 AM
04 450fse Starting problem gasser-downunder Enduro Engine 4 stroke (including EFI & Exhaust) 4 04-25-2007 05:54 PM
03 400fse starting problem smnl4l Enduro Engine 4 stroke (including EFI & Exhaust) 3 04-15-2007 10:20 PM
starting problem Dicko Enduro Engine 4 stroke (including EFI & Exhaust) 8 03-06-2007 04:16 PM
