Old 01-17-2008, 12:32 PM
ramcclure200's Avatar
ramcclure200 ramcclure200 is offline
Default Torque Spec's Triple Clamp Pinch Bolts?
04 DE 200 with 45mm Zokes, what is the recommended torque for the top and bottom triple clamp pinch bolts?
The info I found list the Triple Clamp bolts 29 N-m / 21 FT LBs / 256 IN Lbs
Is this correct?
Old 01-17-2008, 12:37 PM
Brian VT Brian VT is offline
Right here: http://www.gasgasrider.org/torque_table.jpg
That may be for WP but should be good for 'zokes too.
Old 01-17-2008, 05:38 PM
Thanks a bunch
Old 02-19-2008, 11:16 PM
AZRickD AZRickD is offline
You try 21 ft-pounds on a pinch bolt and you'll snap it.
Old 02-20-2008, 04:36 AM
Eugene Eugene is offline
16Nm with 1/4" drive torque wrench as per the table in the technical section, no problems yet.
Old 02-20-2008, 05:28 AM
MattR's Avatar
MattR MattR is offline
Yes, that table was developed back when the WP forks were on the bike. I talked with Glenn (GMP) about the Marzocchi forks and the lower bolt torque should be reduced slightly (helps prevent binding/friction).
WP forks:
Triple clamp upper bolt = 20 N-m / 15 Ft-lb
Triple clamp lower bolt = 16 N-m / 12 Ft-lb
Marzocchi forks:
Triple clamp lower bolt = 12 N-m / 9 Ft-lb
Matt
Current: 2009 Yamaha FZ1
Old 02-20-2008, 06:50 AM
Either fork doesn't need much. Les told me he has seen forks with the internal anodizing worn completely away in the lower clamp area from over tightening. I run mine around 10 -12Nm but may even go lower as long as they don't slip. Also consider that if you antiseize the bolts like you should, this can increase the overall torgue by as much as 30% for the same wrench setting.
GGs aren't that bad, if you ever work on a new Husky you wonder if they ever calibrate the wrenches at the factory, some of the bolts are crazy tight.
FWIW, a friend of mine in town went out riding after working on his KTM the night before. He said for some reason the forks worked great, he felt like a hero. To his surprise he discovered that he had never torqued the lower clamp, it was just snugged up!
Triple clamp ?? rippn450 Enduro Suspension 22 04-18-2011 09:21 PM
Front axle bolts Torque setting biggstr6 General Discussions & Announcements 6 04-23-2010 08:01 AM
Top triple clamp pharrell Enduro Chassis & Body 10 01-16-2009 12:57 AM
BRP top triple clamp Link General Discussions & Announcements 1 11-08-2007 08:28 AM
