Fuel pump replacement
hello everyone, I'm the new owner of an 03' 450fse
the bike doesn't seem to prime when the key is turned. and b y some odd turn of events, my trusty volt meter is missing! alternatively, I removed the fuel pump assembly and directly tested 12v on the pump motor, it received the power, moved very slighty but didn't turn like it was frozen. is there anything I should check before ruling that the pump is bad? if it is indeed faulty, where can I find a pump for a decent price? can my current pump be refurbished? any and all help is apreciated! |
First check your getting good voltage from the relay(back cover,rh side)bearing in mind it's a tachometricly controled unit.
The pumps have been generaly reliable.The wiring and switching not so. Good luck finding oem. In an old thread here,someone used an airtex e7000 pump as a replacemnt. I guess any intank 12v pump of similar dimensions would do the job. |
Are there any specifications that I need to look for in a new pump? Does each pump have adjustable pressure and what does the gasgas call for? |
Where could I find a pump like this?
What Else would I need for the setup? Ie pressure regulator? |
Tags |
fuel, pump |
400FSE Fuel pump question | Gi_GASGAS | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 12-31-2019 03:58 PM |
Looks Like I got A Bad Fuel Pump | Boomhauer | All Other Bikes... | 11 | 11-22-2011 08:25 PM |
03 450 fuel pump voltages query | hillbilly | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 09-22-2010 04:21 PM |
Fuel pump relay-where is it? | sanderjavant | Enduro Engine 4 stroke (including EFI & Exhaust) | 19 | 08-26-2009 12:31 PM |
