When to replace wheel spokes and nipples
Hi so my bikes 15years old and the spokes & nipples are a bit rusty, when should I replace them, do I even need to ? , I got quoted ?400 to renew/ spay the wheels and change the nipples & spokes and have the centres coloured any colour i wanted, I understand there's a fair bit work involved in doing all this,
But if I can get away with just giving them a clean up that would be great. Cheers for any help |
Why $
If they arent bent or too rusted to tighten and keep the wheel true and you don't want to spend the money I'd keep em as is. If the spokes arent bent Spray them with a good penetrant oil liquid wrench etc. let em sit and do it again maybe apply a little heat if they dont come loose but if you have to do that I'd remove tire and rim strip and check for oxidation on the rim + you dont want to melt the strip or tube. I've never heard of decent spokes losing their tension beyond being trued.
Good luck Stoby |
Hi Stoby
Thanks for the advice, I appreciate it ! |
run a small wrench along them like strumming a guitar string. They should have a pretty nice ring indicating they're tight. If one or more just make a dull thud then it (or they) are loose. I check mine every couple of rides in case one has broken or been damaged but after having tightened them occasionally since new they have never loosened since. If you have to tighten them do them slowly while alternating between the loose ones and don't over-do it at one time. If they won't tighten, then yes, time for a hacksaw and new spokes haha!
My worst lesson for this was a TTR125 I bought new for my son many years ago. It was one month old and while following him it looked like the wheel was gong to separate. Quality... not. We were camping over a holiday weekend in the mountains and it took me about 4hrs with the bike suspended on a block of firewood to get the wheel trued up.
Pretty much what everyone else has said, if you can tighten/loosen the nipples there is no need to change them, if some get loose and you can't tighten them then don't waste any time replacing them or the loose spoke will start wearing the spoke hole on the rim (poss hub as well) and you will then need to replace the rim as well
Cheers for the advice there fellas, going to check to spokes and nipples today ,
Good tip strumming the spokes, and how not to wear the rim out, cheers |
Spokes rear wheel | einsteingarage | "Wanted to Buy" & "Want To Trade" | 12 | 12-16-2014 04:48 PM |
Cylinder Bleeder nipples | PEB | Enduro Engine - 2 stroke | 2 | 11-22-2011 06:23 PM |
Spokes/nipples | Hapnin | Enduro Chassis & Body | 4 | 07-13-2008 07:14 PM |
