Old 09-19-2015, 02:25 PM
forgiven forgiven is offline
Default Rear brake bleeder issue
I needed to replace my fluid in the rear brakes due to boiling. In the process I was trying to use the rear bleeder. When I turned the lock nut on the bleeder the whole bleeder started rotating out. Tried numerous times to unfreeze it. First what kind cross over and two when I go to put it in I know that it threads in but I don't see a way to tighten it.
2010 ec300 btw.
Old 09-19-2015, 06:26 PM
There's no lock nut on the bleeder. It just unscrews.
You should only have to loosen it a couple turns for fluid to come out.
You can see in the pic below how unseating the nipple opens the port in the caliper. The fluid then travels through the hole out the center of the nipple.
Old 09-20-2015, 06:48 AM
Perhaps the port is plugged. Fluid was coming out around the threads. I have had the plastic cap on the whole time me.
Complete Nissin Rear Brake System + Enduro Eng. Brake Disk Guard mcnut Parts 5 01-19-2015 01:13 PM
Brake line issue singletracker Enduro Chassis & Body 15 10-23-2012 10:44 PM
Cylinder Bleeder nipples PEB Enduro Engine - 2 stroke 2 11-22-2011 06:23 PM
rear brake line issue skid jackson Enduro Engine - 2 stroke 1 08-16-2009 09:05 PM
