Old 05-02-2023, 08:29 AM
Iceman73 Iceman73 is offline
Default Adding keyed ignition 06 ec300
Hi all, I have an 06 ec 300 in beautiful shape. I'd like to add a keyed ignition to it.
I purchased an ignition from Motocrosscenter.com, it has 3 male space terminals on it. I figured I'd just wire it in parallel with the killswitch, hoping to keep the killswitch as well.
Looking for a little help to make sure I do it properly. 🤷*♂️
Old 05-02-2023, 07:45 PM
Neil E. Neil E. is offline
Simple enough. Take a multimeter to the switch terminals in the OFF position. Find two that have continuity and check that they go "open" when the switch is ON.
Also check for continuity to the switch housing since if it is attached to the bike frame, it will become grounded. Switch terminals generally do not have continuity to the housing.
The "closed" terminals in OFF get wired accross the kill button.
Old 05-04-2023, 12:36 PM
Thanks for the fast reply Neil, I appreciate the help. Coincidentally I'm just up the road from you in Barrie Ontario. You may have seen my ad on Kijiji or Marketplace for this bike.
Old 05-07-2023, 06:08 PM
I've seen a few of your posts on ADV Rider. I only ride single track in Simcoe since the Ganaraska forest became a disaster area.
Old 11-17-2023, 06:14 PM
ditezz ditezz is offline
You would need to connect it in series with your kill switch
Old 11-17-2023, 06:24 PM
sorry, Im in correct
Ignition Lock EC300 07 stian Enduro Electrical & Wiring 5 05-02-2023 12:57 PM
Need a new keyed ignition switch. Help! fst96se Enduro Electrical & Wiring 3 11-18-2019 09:07 PM
Can someone help me with a adding a headlight to a 99 EC300? Need electrical help. flatout111 Enduro Electrical & Wiring 6 11-28-2012 09:38 AM
ec300 ignition cover RiverRight Enduro Chassis & Body 2 08-17-2012 05:01 AM
EC300 -2011 ignition timing FinGas Enduro Electrical & Wiring 9 04-10-2012 06:30 AM
