Old 05-25-2015, 07:57 PM
lou1265 lou1265 is offline
Default 2015 xc300e PV bearing
Anyone else have an issue with the little bearing at the power valve adjustment screw on a 2015 XC/EC ?? I've been through two of them now in 12hrs ! .... makes a horrible screeching noise.... first one was replaced @ the dealer under warranty and only lasted one ride ! .... seems they may be starving for oil as they're a shielded but not sealed bearing .... I may try to find an after market one with no shield (all open) and see what happens ...
Old 08-16-2015, 06:38 PM
Dirt Dud's Avatar
Dirt Dud Dirt Dud is offline
Lou what did you do with the bearing ? Did you get it fixed ?
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES
Old 08-30-2015, 07:39 PM
Default All is good
Yeah ..... all is good, I installed an open bearing with no shields/seals and it has been good for a while now. Not sure what type of bearing was originally in there as it completely came apart. I've been running it pretty hard and it's been a very solid machine .....absolutely no complaints whatsoever !!
Old 08-31-2015, 04:42 AM
RussBroom's Avatar
RussBroom RussBroom is offline
For future reference, the metal shields in shielded bearings are easily removed with a small pick or scriber.
(This is a general tip, not necessarily specific to PV's)
2015 XC300e lou1265 Pictures & Videos 8 06-03-2015 05:25 PM
2013 Gas Gas XC300E - Oklahoma City phoenix Used Bikes 0 05-16-2015 10:12 AM
2014 XC300E limp shifter mtnmanseth Enduro Engine - 2 stroke 1 03-24-2015 05:47 PM
