Reed spacer removal.
Is it safe to run an 02 300 without the spacer? I am loking to pep the bike up a bit, just double checking as I remember something about it possibly causing a lean condition. I have the LTR needle with 42/178 clip #2 spot ridden at 500-5000 feet
Paul B |
It will be fine without the spacer. Biggest hassle may be the airboot taking a set from years of it being installed and being a few mm short. Clamp the carb in the airboot first, use a hair dryer to soften the rubber, pull it into position and tighten the RAD valve clamp.
Screws may be too long. I had that problem. Do it though, b/c it woke my 250 up quite a bit.
Blanco Current ride: 2009 WR450 Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F |
Screws were a bit long, the bike definately comes on the pipe quicker. The carb seemed to fit just fine without the spacer though I had the subframe bottom bolts out to get it snug.
Paul B |
Reed Spacer for EC 250 | GG27 | Enduro Engine - 2 stroke | 4 | 03-28-2009 12:59 AM |
05 Reed Spacer | dozerash | General Discussions & Announcements | 13 | 02-07-2009 07:49 AM |
reed spacer | reeve | Enduro Intake/Carburetion - 2 stroke | 5 | 11-28-2008 09:19 AM |
Reed spacer | clerky clerk | Enduro Engine - 2 stroke | 1 | 09-22-2008 03:31 AM |
reed spacer? | moff747 | Enduro Intake/Carburetion - 2 stroke | 2 | 02-26-2008 10:26 PM |
