2011 EC300 jetting
What are you guys running in your 11 300s, and 250s for that matter?
I have the stock needle and a CCK at my disposal. 1000 ft ASL. Thanks Scott |
11' 250xc, upstate New York 150'- 2500'
pilot=42 needle=nedw 3rd (optional needle from an late model Suzuki rm 250) For the 300 I would use an NEDJ(half a step leaner) needle in the 3rd. main=172 AS= 2 turns out Stock #7 slide I couldn't be happier with the jetting. It's crisp and clean from top to bottom, and the plug looks perfect. The CC* and DD* series needles are gas hogs. I could not even go 32 miles on a tank of gas with either needle at race pace(A-Vet). They also hurt the topend and the bikes ability to climb back into the topend when the throttle is chopped. It felt like the bike needed a lot more clutching. But the one good thing about those needles is that they are smooooooth. The Stock needle is a throw away. |
11 300 EC, CCK needle 2nd pos from top, 175main, 38 PJ, A/S 1 1/2 turns out. One of the things that I did that cleaned it up significantly was lower the float height roughly 2mm. Don't know why this changed things as much as it did but huge improvement, highly recommended mod.
Some of the other local guys here are running KTM N3.. needles, or Kawi needles or a YZ250 needle. I'm happy with the CCK and I get roughly the same mileage as my buddies on their KTM 300's. |
You might want to confirm your Carb size 36mm or 38mm and ask for the size when getting jetting settings. Gasgas sent some bikes with 36's & some with 38's.
I got a 36mm. I would have preferred the 38 that the spec.s said they come with , but ... |
What are guys running in the 36mm carbs?
Without squishes mods, jd blue, at Jd's recommended pj and mj, or nedw clip 3 40p 170m 1.5 out if completely single track, doesn't idle as well as jd, not as torquey but very linear and clean. With s3head I go up a pj and 175 main, in sand I go 175 main stock, 178 s3 head. Sea level to 3500'
2011 ASII 36 Jetting - what were they thinking? | Neil E. | Enduro Intake/Carburetion - 2 stroke | 39 | 06-26-2011 09:01 PM |
2011 125 6 days jetting | orangezuk | Enduro Intake/Carburetion - 2 stroke | 11 | 04-28-2011 11:09 PM |
2011 SixDays 250 JD jetting (YZ kit) | thumperrider1 | Enduro Intake/Carburetion - 2 stroke | 3 | 04-24-2011 08:04 PM |
Jetting for 2011 xc300 | jeffs2200 | Enduro Intake/Carburetion - 2 stroke | 18 | 04-08-2011 04:09 AM |
2011 jetting | mikemoto | General Discussions & Announcements | 7 | 01-22-2011 03:16 PM |
