Source of carb vent filters?
Someone mentioned on this forum that they used minature air filters on the four vent lines of their carb. Since these lines vent the carb, it seems like a good additional way to keep dirt/grit out of the carb.
I searched for the original post, but I couldn't find it. Does anyone have a manufacturer/model number of a suitable miniature air filter? Thanks. Dale |
I recall a thread mentioning the use of 35mm film canisters with foam inside. Maybe team Gas Gas used this configuration?
For the vents routed to the airbox, I used a small medicine container. You could use a 35mm film container too. Just put a hole in the bottom and route your vent tubes into the container. I put some pillow stuffing inside the bottle to filter, but some foam would do the same. Then, I put the cap on which had a hole in it so it could breathe.
Here is a pic of mine installed.
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
To think I just shove 2 pipes in the airbox and leave 2 dangling without filters
Uni Filters for 2010 | Rod Overstreet | Enduro Intake/Carburetion - 2 stroke | 5 | 07-09-2010 11:15 AM |
Ohlins parts source? | widebear | Enduro Suspension | 2 | 04-02-2009 01:31 PM |
AFE Air filters | roostafish | Enduro Product Reviews | 8 | 03-21-2008 03:17 PM |
Carb Vent Tube Diameter/Size? | Captccb | General Discussions & Announcements | 1 | 11-05-2007 02:36 PM |
