#31
Here's a macro pic of the clutch fingers...
#32
Here's the hub
#33
Close up of the finger tips...
#34
That looks fine. If the plates and springs are OK then start looking at the master/slave for a leak that allows pressure to bleed off, reducing travel and increasing drag. Bleed first of course.
#35
The steels are fine. The fibers are out of spec (just under the limit) and the springs are out of spec (a bit more than just under the limit).
If I could buy a set of fiber plates and keep my steels, I would. I need to get the frictions and springs for sure. Then bleed the system. Good to go. I don't know if GoFasters can get me the parts in time to get me off to the Camp-n-Ride by Friday morning, so I might just go local (MonkeyButtParts.com) and do Moose or equivalent. Any detractors? Rick |
#36
I've installed the DP clutch kit (next-day service from MonkeyButtParts). I noticed that one of the steels had a half-inch section on the outer radius that was flat (like a machining error). I decided to use one of my old steels instead.
I bled the line using the syringe technique. Using the syringe to pump clean fluid back up to the reservoir does wonders to flush out hidden bubblets. My old fluid was amber (old). Nice to get new stuff in there. With the new fresh fluid, bleed, steels, fibers, and springs, the clutch lever gives me more resistance. I watched the plates move in and out a few milimeters (I don't know what standard is). I'm going to fire it up and see if it actually works. I'm going to defy the GasGas common wisdom and use a 50/50 of ATF and synth Rotella. Let's hope I didn't screw something up. |
#37
I ran 50/50 Type F ATF and 10W-30 in my old '98 EC250. That bike was still on the original clutch when I sold it in April of '07.
#38
I run Amsoil 0W-40 with good results. Really helps in colder weather.
2002 Gasgas EC250 (gone not forgotten) 2012 Ktm 300xc 2001 Gasgas EC300 Lifes journey is not to arrive safely at the grave in a well preserved body, But rather to skid in sideways totally worn out shouting holy cow what a ride !!!! |
#39
I fired it up and took it easy up and down my street. So far so good. I can kick start it in gear and it doesn't drag. The clutch lever modulates well. Smooth shifting. And neutral is a bit more positive (Before the swap I sometimes had to search for it more than I like).
Good thing I took it easy. As I was putt-putting down the street I heard a ting-ting noise. My axle wrench had just fallen off the nut as I had been riding around with it all that time. I decided that discretion required me to coast into the garage to see what else I had forgotten to do. I'm just not very good with tools. |
#40
I'd like some more info on this "syringe technique" for filling and bleeding the clutch res.
Thanks. |
Does your clutch drag? | stay_upright | Enduro Engine - 2 stroke | 11 | 06-05-2008 03:14 AM |
Clutch Drag? | Gas Huffer | Enduro Engine - 2 stroke | 5 | 12-11-2007 05:02 AM |
05' EC300 Clutch Drag | gasIdaho | Enduro Engine - 2 stroke | 18 | 09-09-2006 02:53 PM |
