Old 09-01-2013, 09:59 AM
flo flo is offline
Default How do you stop the brake pedal bolt from bending on the 2010/11 frames?
I need to replace the brake pedal bolt almost every ride because it gets bent and the pedal will hit the footpeg mount -> no more rear brake. Tried just about every type of bolt I can get my hands on...any ideas? Anybody have the same problem?
If you don't have that problem and your brake pedal stays in the right position, a picture or details of your setup would be very much appreciated.
Bike is a 2010 EC300
Old 09-01-2013, 05:11 PM
Done 8000kms+ with no issues bending bolts on a 2010 model.
The rear brake runs in a bushing which can flog out over time. Checkpoint offroad make a nice replacement which holds up better and takes alot of play out of the pedal.
PART NO. 5007
GASGAS Rear Brake Pedal bushing
http://checkpointoff-road.com/store.html
Old 09-01-2013, 05:20 PM
andoman's Avatar
andoman andoman is offline
I have had no problem with the bolt bending using the stock bushing either. I even have a spacer that pushes the bolt outboard so the brake clears my taller Reklus clutch cover.
But since you are having problems: any hardened bolt of the correct length should work fine.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
Old 09-02-2013, 05:53 AM
n_green n_green is offline
Same, no issues at all on my '11, and I've hit a stump hard enough to flatten the brake pedal foot grip thingy.
Old 09-02-2013, 10:35 AM
gasgasman's Avatar
Is the bolt actually bending, or just the mounting bracket?
Old 09-02-2013, 03:26 PM
nambo-trev's Avatar
I was going to ask this same question because I've bent the mount a bunch of times but the bolt hasn't bent
trevor
Old 09-03-2013, 03:39 PM
flo flo is offline
thanks for all the tips! i've ordered one of those fancy checkpoint bushings, that should definitely help to get some of the play out and make the whole assembly more solid.
Old 11-10-2013, 07:16 PM
flo flo is offline
Just to follow up on this, the bushing solved the problem and everything works great now!
Wanted: brake pedal, shift lever for 2010 EC300 flo Parts 0 07-05-2013 02:55 PM
brake pedal randy Enduro Chassis & Body 3 02-10-2011 04:37 PM
Scorpion Rad Frames-2010/11 EC-Install Pics JP4 Enduro Chassis & Body 4 02-07-2011 07:33 AM
Help with brake pedal please!!! stemplin Enduro Chassis & Body 8 01-30-2011 11:52 PM
Brake Pedal Rick Enduro Product Reviews 3 12-08-2008 08:44 PM
