Old 06-18-2008, 04:42 AM
Warwick Simpson Warwick Simpson is offline
Default Slipping kickstarter
07 ec300 with 14hrs. Accasionally slips when the kickstarter is pushed through its stroke. Any ideas and is this a common problem with the 07s.
Old 06-18-2008, 09:44 PM
gasser's Avatar
gasser gasser is offline
Yes my 07 ec250 had the same problem. The problem was the engagement spring was too weak. As your transmission oil gets dirty it causes drag on the shaft that the engagement gear rides on and the weak spring won't push the two engagement gears together fast enough to interlock. The spring is noticeably weaker than the spring in my 01 xc300.
KEN
Old 06-19-2008, 03:28 AM
My 03 seamed alot stronger too. Did you find a solution? Do the earlier model springs fit. I am useing Redline MTL gearbox oil which still slips when new.
Old 06-20-2008, 06:07 PM
LAWMAN's Avatar
LAWMAN LAWMAN is offline
mine (07 300) did this & I ended up having to replace the ratchet gear or whatever it is called for the starter. happened in the 1st hour of a 2-day riding clinic w/lots of stops & starts, it made for an aggravating w/e....
Old 06-21-2008, 03:17 PM
gasser's Avatar
I took the spring and gear out of mo 01 xc300 (which is down for other work) and put them in my 07 ec250. If you get a stiffer spring right away you won't have to replace the gear.
Old 06-22-2008, 07:35 AM
DaveJ DaveJ is offline
Check the teeth on the dog that's attached to the kick starter. I had broken all the teeth off of mine.
'06 GasGas EC300
Old 06-24-2008, 01:46 PM
Have pulled it apart. Both gears are partially striped. My dealer tells me the part no. for the spring is the same for 03 and latter so why are the 07s haveing thi problem. Is there any advantage in stretching the existing spring?
Old 06-24-2008, 02:38 PM
Loosenut's Avatar
Loosenut Loosenut is offline
On my 2000 EC300, I had to replace the kickstart ratchet pinion twice due to improperly hardened parts. Not only that, but some of the metal fell between the shiter actuator plates leaving riding out in 1st gear.
Mike Baxter
2005 GasGas EC300 (Ohlins front and rear)
2007 Yamaha FZ1
2003 Pampera 280(hers)
Old 07-11-2008, 03:26 PM
catch22 catch22 is offline
yep same thing happended on my 05 gasgas 250 after about 18 months from new , a bit longer than your one lasted , but come on this can't be rocket science can it ?
FSR 450 2007 clutch slipping chapp44 General Discussions & Announcements 11 08-05-2009 02:00 PM
Kickstarter Triple W Enduro Engine - 2 stroke 1 07-31-2008 05:01 PM
Slipping clutch nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 12 06-18-2008 08:14 AM
kickstarter crazjarhead Enduro Engine - 2 stroke 6 08-13-2006 07:51 PM
