Old 08-11-2018, 01:56 AM
nitroman nitroman is offline
Default Re commissioning the fse400
G'day people's, I haven't been here for a while, the gasser has been parked while I've been riding a BMW gs 1200 the last few years.
Anyhow I've been invited to go to an enduro weekend at sunny corner near Bathurst nsw by my new boss so I've got the old rig running again.
I tried jump starting it at first and the fuel pump was dead, I got one from Italy(same as a smart car's pump) and a new lithium battery(so light) and gave it a crank. It eventually fired but wouldn't idle so I pulled off the throttle body for a clean and discovered a crack in the intake that I replaced with silicone intake pipe From the local auto shop. It fires up and runs sweet now but what else should I do to get it up to speed after a long sleep?
I've changed the coolant (with the Evans waterless stuff) and oil and filter, and I'll put new rubber under it, but any other suggestions?
Old 08-19-2018, 05:18 PM
Harry's Avatar
Harry Harry is offline
Nitroman,
The only thing I can think of is to change the brake fluid, start it, ride it and report back here
I am busy fitting a DRZ400 motor into a FSE400 frame, so I keep an eye on the four stroke threads.
Regards, Harry
Old 10-27-2018, 09:18 PM
Adam_redneck Adam_redneck is offline
I?d also change your oil!
Crank sensor 03 FSE400/450 Adam_redneck Enduro Engine 4 stroke (including EFI & Exhaust) 0 04-19-2018 12:06 AM
FSE400 throttle tube nitroman Enduro Chassis & Body 0 12-22-2007 05:17 AM
Fse400-02 plastic raggamuffin Enduro Chassis & Body 1 01-30-2007 02:34 PM
