2001 300 ec Rear Axle Nut
Cheers!
01 gas gas 300 ec. My rear axle nut came loose and fell off somewhere on the trail my last ride. Luckily no damage happened. I am having a hard time sourcing a new one. Anyone know any crossover part numbers or the nut size? Thank you |
didn't really check, but my guess would be M20x1.5.
What diameter is your axle? If you cannot find out, I can measure over the weekend I only have newer axles to measure, but I think they are equal Sent fra min YAL-L21 via Tapatalk
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc Last edited by Anders; 10-05-2022 at 02:52 PM. |
Is your axle mounted the correct way? The nut should be on the disc side .If the axle is mounted the wrong way ,the nut can be loosened when struck by a rock or other trail object
[QUOTE=ditezz;200590]Ahhh....It is a self locking nut .That would explain it being on the sprocket side ,I would still put it on the disc side ...anyway Part # BE25618023 Self Locking nut r640700
My rear axle nut good | Gez | Enduro Chassis & Body | 12 | 01-25-2020 01:20 PM |
Rear Axle | Preszo | Enduro Chassis & Body | 2 | 01-27-2014 11:10 AM |
Rear Wheel Axle | singletracker | Enduro Chassis & Body | 38 | 07-24-2013 09:08 PM |
rear axle Q | nokturnal | Enduro Chassis & Body | 4 | 06-13-2012 10:52 PM |
rear axle nut | skid jackson | Enduro Chassis & Body | 2 | 06-17-2007 06:52 PM |
