Ride Reports Tell us all the gorey details! |
gasgasman's 2015 250R ride report
I did a two day shake down of my 2015 250R GasGas.
All clean before heading out. Did all my transferring of my essentials off my 2011 bike last week. Flexx Bars,G2 hand guards, Fastway damper and mounts, and Magura clutch master cylinder. Initial settings: Tires-F-OEM. R- Bridgestone E30R Final drive-Stock- 13F 48R Power valve adjuster- Stock setting. Fork- C-7 clicks IN from full out. R-10 clicks IN from full out. It is best NOT to turn the fork adjusters in all the way. The needle seats are soft and can be damaged. Shock-C-12 clicks OUT, R-22 clicks OUT 105mm sag. Carb(ASII)-OEM settings- 172 main, 42 pilot. Clip in the middle spot. Day one. Not too dirty. Trail conditions-wet and sloppy. Lots of standing water. Some spots were perfect. Gave the bike 2 kicks to light off,Took off from the trail head. Bike feels nice and tight. Very smooth with no vibrations. Tracks very well. Handles like it's on velcro. It out handles my 2011. Comfort- Very plush. Ergonomics is the same as my 2011 bike. Bike is narrower and has an easy transition to slide up to the front of the seat. Slightly taller. Seat hard-Just right for me. I got acclimated within 1 mile of riding. Carburation: Bike is running rich. Not crisp and very little bottom end power. Bike was ridable. Just could not rail like I wanted. Front suspension. Felt good, stayed high in the stroke. Front wheel would fall into the whoops. Braking bumps would shudder the handle bars. I sped up the rebound 4 clicks, front wheel would skip over the whoops now. I still have to play with the preload adjuster. That will help on the shuddering. Rear susp. Felt planted. It would kick on some whoops. Turned the compression in 2 clicks. That helped get rid of some of the kicking. I still get a wack in the butt from the seat on very big whoops. Handling. Bike tracks straight, ruts are no problem. Doesn't try to climb out of the ruts.The tires really stick well on the trail.When powering out of turns, the rear tire does not step out. I've always said my 2001 Gas Gas was the best handling bike I've ever owned. This '15 is way better. Carves turns with surgical precision. Gearing- A little tall. Had to down shift a lot .I'll switch to a 49T rear sprocket. Day two: Filthy girl. I put in a red JD needle I had in my collection-clip middle position. Air screw-2 turns out. Took off on 1st loop. Very impressed- The bike really rips now. Good low end power. Revs faster. Now I have my mojo back. Back up to speed and running the race pace now with my buddies. The bike is very composed and handles the trail junk well. My cornering speed is way up. Very confident inspiring. I still have to play with the power valve adjuster and fine tune the suspension some. It does feel better balanced than my '11 with the KYB forks and the TTX rear shock. The ONLY negative (if you want to call it that) thing I can find with the bike is a rattle from the chain at times. Sound like someone's throwing rocks at the skid plate. I have tuned it out. I am very happy with the bike. No regrets all with the purchase. I am definitely faster on this bike. The "usual suspects"! Thanks to Simmo737 and Rod Overstreet for their set up tips. Last edited by gasgasman; 03-30-2015 at 09:41 PM. |
2015 MTDR Spring Ride @ Loretta Lynns | skraMnoR | SouthEast United States | 6 | 03-25-2015 07:35 PM |
Wudi 17 Ride/March 5-8, 2015 | Jim Cook | General Discussions & Announcements | 37 | 02-25-2015 04:21 PM |
Honda DI 250r for 2015! | nambo-trev | All Other Bikes... | 3 | 04-01-2014 07:31 PM |
First ride! Report | ucrtwf | General Discussions & Announcements | 5 | 11-20-2011 07:49 AM |
Houston Area Ride with the GasGasMan! | coopernicus | Republic of Texas | 1 | 08-24-2010 05:08 PM |
