Vent tube for powervalve
I changed the oil on my bike today and decided to remove the plastic glide plate. When I removed it I noticed that oil started leaking all over the left side of the frame and on the ground. I found that the oil was coming from the vent tube coming from the powervalve cover. The tube had been crimped by the skidplate ever since I bought the bike and at least 3 to 4 ounces or more of oil had built up inside the powervalve cover.
I guess my question is does this seem normal to have happened with the vent blocked? Could this have been causing a lack of performance? I ended up taking the cover off and cleaning up the area and rerouting the hose so it is not crimped. The bike starts and runs great but I have not been able to ride it to see if it performs any better. |
it is normal. The bike in standard form actually has the hose doubled back and zip tied closed, and i have read that normal maintenance should involve opening it up and draining it from time to time. If a lot of oil came out (i am a metric guy!) it may have been affecting the Performance.
on my 2010 i have just left mine open as it has been on all my other bikes so it drains out all the time. I am not sure what GG reasoning is for having it closed, but i can only see it becoming a problem in really deep river crossings.
Ok, so I guess I should go ahead and leave it open then. I figure it must have a negative impact on performance. The volume in the powervalve cover area would have been near zero with that much oil in there.
I still have plenty to learn about the powervalve operation on the GasGas. It is a much different system from the KTM. |
By trapping the residual oil you were diminishing the effect of the PV system because the resonance volume was reduced. Make sure you keep the drain clear, and you may want to look at a cleaner burning oil the leaves less splooge.
Steve, I believe the proper technical term is "spooge".
Which one? Moe, Larry, or Curly?
'11 Husky CR150, '11 GasGas XC 300-E, '11 Kawasaki KX250F, '71 Hodaka ACE 100B+ |
I am not sure I could find a much cleaner burning oil. I am running mobil1 2t full synthetic at apprx.50:1. I never have any spooge at the silencer. I am pretty sure the drain has been blocked since new and the bike has about 25 hours now. That is quite an accumulation of spooge. I have thought about adding the larger pv cover but I may decide to add the estart so I have held off. |
New 2010 EC300 - NOOB Powervalve Vent Question | JP4 | Enduro Engine - 2 stroke | 2 | 11-29-2010 07:48 PM |
Power Valve Vent Tube?? | EtienneNZ | General Discussions & Announcements | 16 | 09-19-2010 09:53 AM |
gas tank vent hose | flybars | General Discussions & Announcements | 14 | 05-17-2010 01:34 PM |
PV vent hose......... Help | joey11 | Enduro Engine - 2 stroke | 2 | 06-16-2008 12:21 PM |
Carb Vent Tube Diameter/Size? | Captccb | General Discussions & Announcements | 1 | 11-05-2007 02:36 PM |
