2013 EC 300 Marzocchi top fork clicker stuck
Hi, I was busy putting all my settings back to stock but the left forks clicker is
not working, it clicks but does not reach the end, so i cant zero it And I cant figure out how to remove the cap, there is a red nut shaped thing up top but does not do anything when i turn it Any help would be greatly appreciated |
A red nut??
Got a picture? Are these 45mm OC or 48mm CC with PFP adjusters. |
Ok, so figured out how to undo the caps
these are 45 OC forks Elevate the bike, and undo the top nut, it might seem that nothing is happening but keep turning, eventually the cap will start coming out then compress the suspension and undo the last bit Checked everything at the top and looks ok, spoke to my mechanic and he reckons the brass screw at the bottom is stripped, so will have to send it in |
Stuck fork cap | kendunn | Enduro Suspension | 4 | 08-11-2014 07:06 AM |
Marzocchi Fork Cap | xdab | Enduro Suspension | 3 | 03-19-2011 08:44 AM |
Marzocchi Fork Oil Change | eff | Enduro Suspension | 19 | 04-03-2008 07:55 AM |
Marzocchi Fork Guides | Eugene | Enduro Chassis & Body | 1 | 02-22-2008 07:32 AM |
