Old 04-30-2017, 05:17 PM
Powerhouse Powerhouse is offline
Default 06 300 de powerband issues *fixed*
Hi everyone, first post here.I recently picked up a rough running 06 300. After reading thru threads here I got her running much better. The bike had real good bottom end and slightly into the midrange and then it would just flatten out and not rev. What I found was an almost completely clogged turbine core assembly in the silencer. Also found a 45 pilot,ddk needle on middle clip and a 158 main jet in it. After disassembling and cleaning the silencer I installed a 42 pilot,cck needle in top clip and a 175 main. The problem I'm having now is getting it into the powerband. It has strong low and mid power but again flattens out past the midrange. If I hold it wide open when it's doing this after 5 seconds or so it will slowly hit powerband and rev out or if I stab the clutch as soon as it starts to flatten it hits the powerband much harder and revs out. I'm thinking I have a jetting issue but wanted to get some insight from anyone that has had this issue and fixed it. Thanks Andy
Old 04-30-2017, 10:47 PM
dANbOT's Avatar
dANbOT dANbOT is offline
Maybe someone who is familiar with the needles you have will chime in, I'm no help there. Have you have tried your needle clip in a richer position? The way you describe it being flat sounds lean to me.
Pretty easy job to pop an exhaust valve cover, and rev the bike in neutral just to be sure the exhaust valve is operating.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 05-01-2017, 12:48 AM
Cox76y Cox76y is offline
Sounds rich to me. Try a smaller main..
Old 05-01-2017, 03:52 AM
Check -
Spark plug (use iridium, i only get 3 rides out of a standard)
Power valve adjustment
Float height
Then try the jetting in my Sig, or close to. The needle jet (not needle) has a tendency to wear over time so leaner needles are required.
Silencer (standard ones break down) (not applicable to you)
Make sure you have a resistor type spark plug cap, non resistors kill cdis QUICK on these
If it's still there. HT Coil, stator coil, cdi. Check all earth points and contacts before changing things.
2016 RM-Z450
Old 05-01-2017, 05:07 AM
If I drop the needle it looses it's crispness down low. Powervalve was checked and is opening .
Old 05-01-2017, 05:21 AM
Plug is a new iridium - br9 eix ,float height is good. This bike has definitely seen a lot of time, it was raced, but was maintained. I am thinking it might be a worn needle jet based on the fact that I need to run the top clip. I also don't think it's idling solely on the pilot curcuit as the idle screw is almost all the way in and the air screw has no noticeable effect anywhere from a half turn out to 3 turns out. I have a new carb on the way and will have it this week. I will set that up with my current jetting and then reassess. Thanks for the replies
Old 05-01-2017, 06:41 PM
Got a chance to try a new needle Tonite. It's out of my old Suzuki rmx 250.... 1472 ... equivalent to a dgn. According to the keihin chart it's leaner than the cck at 1/8-1/4 throttle and richer from 1/4-3/4. I installed it on the middle position. After warming the bike up I gave it a quick ride down the street. It definitely smoothed out the power down low but still had plenty and was good til wot. Then It just flattened out, definitely lean. I then swapped out the 175 main for a 185. This worked wonders. Smooth power all the way. No sign of a powerband hit just smooth revs to redline. I'm gonna pick up a 180 main and play with the clip position to try and lean it out a little so it's not so 4 stroke feeling but definitely made steps in the right direction.
Old 05-02-2017, 05:19 AM
That's surprising, mine rips your arms clean off!
2016 RM-Z450
Old 05-02-2017, 05:57 AM
julianorettore julianorettore is offline
Exclamation
Did you check the ignition timming to see if it is correct? It may be that the ignition is with the delayed point and this inflates directly in the acceleration of the motorcycle (translate by google :-))
Old 05-02-2017, 06:10 AM
Im feeling it's a little too rich thru the mid and top right now which is softening the hit. I ordered a couple different needles in between the cck and the dgn plus a 180 and 182 main and will keep testing. This engine is all stock also so I'm sure it has a huge squish area and lower compression than yours which certainly doesn't help powerwise. It feels about equal in power to my 450 exc ktm but not even close to my CRF 450r
What causes the dip in my powerband? pandomar Enduro Engine - 2 stroke 8 07-06-2016 02:09 PM
Will not reach powerband 06`EC300 stian Enduro Engine - 2 stroke 54 06-02-2016 04:37 PM
minor dip in the powerband pandomar Enduro Intake/Carburetion - 2 stroke 6 10-29-2015 11:35 AM
Gas gas ec300 not hitting powerband candybuddy Enduro Engine - 2 stroke 10 08-13-2014 12:33 PM
SIX DAYS 300 powerband vavido Enduro Engine - 2 stroke 2 11-18-2008 01:28 AM
