2023 Rieju Racing 200 LED relay
Trying to understand. The 2023 Racing comes with a relay, that should be LED-capable (the manual says diodo, so should be LED). But when I plug in a single (in case that matters) turn signal, it doesn't flash as much as just dims.
It may be a case of plugging two on one side, I suppose. I just did a Wr250F conversion, and one signal alone worked fine when testing the wiring. Thoughts? |
So it has nothing to do with 2 or 1 LED units. 2 made no difference, but hooking up a regular bulb resulted in blinking.
Just need to find a replacement LED relay which this clearly ain't. |
2023 Rieju 300 factory jets. | Ud_luz | Enduro Intake/Carburetion - 2 stroke | 1 | 07-03-2023 03:29 PM |
flasher relay | pigpen966 | Enduro Electrical & Wiring | 2 | 07-12-2018 05:22 AM |
2010 relay prob? | nato | Enduro Electrical & Wiring | 0 | 02-16-2012 02:31 AM |
Indicator relay | Hicksi | Enduro Electrical & Wiring | 5 | 08-22-2011 09:52 AM |
fuel relay | Devondan | Enduro Engine 4 stroke (including EFI & Exhaust) | 4 | 10-21-2009 04:12 PM |
