Old 03-14-2014, 06:18 PM
jt633 jt633 is offline
Thanks only dislike was 1. How difficult it was to get spring on and 2 the clevis wouldnt wind down as low as i would have preffered
2004 ec 300
Old 04-02-2014, 09:54 AM
Thumbs up
My Geko brake pedal is slap worn out from all the mud riding this past "winter".
I went ahead and put the 2008 YZF 450 brake pedal on my bike.
Went really easy. The YZF pedal is nice and solid. No slop at at all.
I cut the GG brake pedal spacer to work with the YZF pedal-I used the short piece. This allows the YZF pedal pivot bolt to fit in the GG frame.
The pedal sticks out too far from the side cover.
I lightly heated up the pedal and bent it to where I liked the position.
My clevis is worn out and the threads stripped out. So I went with the YZF clevis. The threads are the same as the GG.
Old 09-22-2014, 05:30 PM
spooly's Avatar
spooly spooly is offline
Them pegs look nice?? Fastway?
Old 01-17-2015, 08:17 AM
Fesart Fesart is offline
Originally Posted by 300ECR View Post
I had the same problem on my 08 300 so I had I machined out and fitted two needle roller bearings. I fitted it wit a new inner bush and it works better then ever before.
Hi, have you got the dimensions of the two needle roller bearings (in,out and lenght)?
Old 09-14-2017, 09:20 AM
Dkskioh Dkskioh is offline
Originally Posted by jt633 View Post
Here it is ended up using washers for a spacer ha trouble winding down master clevis
But got it as low as i could
Did you have to trim and re-tap the GG pivot bolt receiver to accept the WR Pivot bolt or does the WR pivot bolt screw right in?
Rear brake pedal wheelie "Wanted to Buy" & "Want To Trade" 1 02-13-2013 01:10 PM
parts crossover - rear brake pedal? stainlesscycle Enduro Chassis & Body 8 06-16-2011 07:05 PM
Brake Pedal 2003 EC 300-KX crossover jb250xcf General Discussions & Announcements 1 03-01-2011 02:36 PM
Rear Brake Pedal Rick Enduro Chassis & Body 4 01-28-2008 01:57 PM
