headlight switch
does anybody know where/what i could buy for a headlight only switch for 1 1/8 bars. its an 05 ec300, dealer edition. came w/no headlight. looks like wiring harness is there. i bought headlight from hebo
05 ec300 01 wr426 98 polaris trail boss |
Make it easy on yourself and wire it in like my bike came from the factory (the '00). There is a simple on/off switch mounted on the numer plate/headlight housing. It is directly in front of the right fork on the backside of the numer plate/headlamp housing. The web on the number plate/headlamp housing is drilled for an on/off switch to mount so you just reach inside and flip it on or off. Unless you want high and low beam? Would still be cheaper to do the same and use a 3-position switch. Make sure it is sealed against water and moisture. Aircraft switches are made that way.
CDI switch on an EC200 | captainslow | Enduro Engine - 2 stroke | 1 | 10-26-2010 12:50 PM |
Dual Map switch.. | stevehipkiss | Enduro Electrical & Wiring | 3 | 01-28-2010 01:29 PM |
Seriously contemplating switch. | REVERUP | General Discussions & Announcements | 11 | 11-14-2009 06:35 PM |
mapper switch or ??????????? | thenutt | Enduro Engine - 2 stroke | 4 | 02-13-2009 07:34 PM |
Kill Switch | Dingo | Enduro Electrical & Wiring | 4 | 12-10-2008 04:23 PM |
