Old 05-12-2014, 10:01 AM
kyton's Avatar
kyton kyton is offline
Default oil drain washer
What size is the oil drain washer and the filler on the 04 ec 200. Can one use and o'ring instead of a copper washer?
Old 05-12-2014, 10:05 AM
eff's Avatar
eff eff is offline
My oil drain plug (2004 EC250) has an o-ring. The filler plug has the copper crush washer.
2004 GasGas DE250
Old 05-12-2014, 10:38 AM
gasser's Avatar
gasser gasser is offline
An o-ring is much better to use on the bottom because it makes the bolt much harder to shake loose than a crush washer. Doesn't need to be tightened nearly as much as a crush washer.
Old 05-12-2014, 10:42 AM
kyton's Avatar
Great. So can i just use an o'ring on top as well then.
Any idea what size they are meant to be.
Old 05-12-2014, 10:49 AM
pscook's Avatar
pscook pscook is offline
I have a bag of teflon washers at home. If you send me a PM later today (12 hours from now) I will look at the dimensions and send along any information I have.
Edit: I ordered McMaster Carr part number 9559K313
PTFE O-Ring
AS568A Dash Number 906
ID 0.468"
OD 0.624"
Phil
(New bike pending...)
Old 05-12-2014, 11:57 AM
kyton's Avatar
this is what i have fount so far. if possible i would like to use oring's all over
Front drain Copper T4008012 8x12 x 1.5
Oil drain Copper ME25810030 12x18x1.5
oil Filler O'ring ME25610026 12x2
Coolant drain Fibre T4006010 6x10x1.5
Old 05-12-2014, 06:51 PM
gasser's Avatar
I buy the vitron o-ring kit (metric) at Harbor Freight. I think it's $10-$12 (often on sale for 8-9). It has 3 sets of exhaust pipe o-rings, probably 10-12 that will fit the drain plug and suspension linkage. In total maybe 2 dozen different sizes. These work great - been using them for years.
Old 05-13-2014, 05:47 PM
cbutler's Avatar
cbutler cbutler is online now
you got a part number Ken.
p.s. still waiting on pics
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 05-14-2014, 01:35 AM
gasser's Avatar
On closer examination these o-rings aren't vitron they are nitrile butadiene rubber (NBR). I have a kit in a red box (#W5203) from Performance Tool and a kit in a blue box (item #67580) from a company called STOREHOUSE. Kits contain @400 o-rings in more than 30 sizes (10-20 of each size). Sizes range from 2.8mm ID to 50mm ID.
p.s. My cell phone that takes pics quit working so I'm back to my old $10 flip phone from WalMart (it has no camera). Maybe I can find Connie's camera.
Old 01-08-2016, 11:31 AM
Ianto15 Ianto15 is offline
Hi guys I'm new to the forum and not really sure how it all works yet. I'm trying to find out if anyone knows if there are any websites (uk) where I can order the oil drain bolt for a gasgas ec 300cc 2004 . Thanks in advance for any replies.
New era rear wheel washer noobi Enduro Chassis & Body 10 08-06-2014 05:17 PM
Clutch Pack Conversion - Thrust Washer Swap JP4 Enduro Engine - 2 stroke 4 10-07-2013 08:00 PM
Lower shock clevis washer substitute? pscook Enduro Suspension 6 08-07-2013 04:57 PM
Exhaust flange Washer Crossover swazi_matt Enduro Engine - 2 stroke 0 08-07-2012 02:30 AM
Rear hub bearing washer kendunn Enduro Chassis & Body 2 02-16-2010 02:27 PM
