#34
Thanks a lot for all the detailed info here. This thread is mainly about your 300 head, although you refer to your 200 as well.
I just measured my '15 200 squish to be 1.8mm (OEM setup, doing the bike's first ever piston replacement now). I haven't removed the cylinder yet, but it sure has a thick base gasket, at least one of the 0.5 ones. If I go with one .15mm gasket, that should bring the squish down in the 1.45 area, a tad too high I presume (if there is a 0.5 gasket now). However, I do have a lathe (and have cut heads earlier) so if necessary, I'll cut it down. I thought about aiming for 1.3mm. Should I go lower? I run 98 octane gas (known as Super around here). What squish height did you end up with on your 200? and what about the CR?
Swopping 1997 Cylinder head with 2005 head | EC250 | Enduro Engine - 2 stroke | 10 | 12-15-2015 10:13 AM |
yet another no idle thread. | stainlesscycle | Enduro Intake/Carburetion - 2 stroke | 86 | 09-03-2011 11:33 AM |
My Go Pro HD Thread | SideshowBob | Pictures & Videos | 18 | 04-25-2011 03:07 PM |
thread | jriley43 | General Discussions & Announcements | 15 | 03-17-2010 03:51 PM |
Another Sprocket Thread | Motarded1 | Enduro Chassis & Body | 1 | 06-09-2008 10:49 PM |
