Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome... |
Billet radiator guards
These are pretty popular with the orange crowd and are now being made for Gas Gas 2Ts.
http://www.bulletproofdesigns.com/gasgasguards.htm |
Oooohhh! Pretty.
Usefull as well as ornimental. How much are they? If I follow the link and get to the websight, my credit card will fly out of my wallet. How much are they? |
I think they're $189.99 US. My next bike is getting a custom pair of those for it. Every bike needs a little bling.
They do look nice but forget about bling for a minute. What do you see that makes these potentially inferior to the flatland guard? No tie back to the head stay, no side coverage, and judging by the hole placement they sit much closer to the radiators, which hurts airflow and provides less room for front impact damage.
For less than $100 you get a set of Flatlands, add TWO sets of GP braces for $60, adding an upper shroud mount. For less $$ this is the most bulletproof radiator protection setup you can get. I crashed hard enough last week to flex the right shroud to the point of breaking the brake fluid resevoir. The side of the Flatland guard was bent toward the rad only about 3mm in the center between the GP braces, they did their job. The shroud was fine, the rubber isolator I use for the upper mount separated and was eaisly and cheaply replaced. |
I have damaged both radiators on my '01 XC300 using precisely the set up you describe. I have since changed to using a combination of 2 GP braces and radiator brace angled back at about 45 degrees to give true triangulation. The angled braces I hand made years ago for my ’01 XC300 are much like the CRD braces I put on my ’06 EC300. I can say based on my long term crash testing on my ’01 XC300, the set up with GP braces and an angled radiator brace is significantly stronger than the GP braces and Flatland guard combination. I also run the stock radiator louvers, which do a far better job than a radiator guard at keeping mud out of the radiator. We have mud for about 9 months out of the year. Mud is a big cooling inhibitor when it gets in the radiator. Here is the set up on my ’06 EC300 with modified CRD braces and GP braces…
Eric,
Completely agree that a 45 deg. rear mount would be best. Perhaps I'll modify the Flatlands in the future. We have a fair amount of mud, but rocks and sticks are the biggest concern. Most of the potential damage is done by slow speed tipover type falls in technical rock sections, where you run out of leg. This is of the side impact varity, that the GP braces do a great job on. In south NJ, the briars and sticks go to work, plastic louvers litter the trails in a south jersey enduro. The Flatlands have that nice margin between them and the front of the radiator. Once I had a baseball size rock kicked up by a rider in front of me hit the guard square in the front. It bent the guard in about 1", but the rad was untouched. They can clog with mud, but most of it clogs the guard not the radiator, at least not to the point of ever causing me a problem. The GG has excellent cooling capicity, unlike my previous KTMs. Do you use an upper shroud mount? This saves plastic for sure. |
http://ktmtalk.com/index.php?showtopic=192810 |
This post is a little biased because I build the BPD rad guards. The reason I started building them is because I crushed all the stamped guards.
I don't need a tie back to the head stay. My guards are cut from solid billet. They don't flex or bend. I have tested them for 5 years. I have yet to have a side impact failure. As for airflow. My guards will dissipate the heat off the radiator and flow much more air then a flatland guard. I don't have any bracing that runs behind the radiators. This bracing only reduces airflow and makes your installs and maintenance more time consuming and tests your patience. I also offer the best customer service out there. If you don't like my product I will give you a refund. NO QUESTIONS ASKED. If you still have questions or concerns check out my testimonials page on my web site: www.bulletproofdesigns.com Thanks, Nate Scott 816-695-3784 |
CRD radiator guards | lordfeyr | Enduro Other... | 4 | 01-18-2010 08:24 AM |
Radiator Guards? | Boomhauer | General Discussions & Announcements | 4 | 08-24-2007 08:42 PM |
