Old 03-13-2008, 08:13 AM
twibs twibs is offline
Default transmission oil on ec250
the oil looks like it has a little water in it,it is slightly milky ,has always gone like this since i had the bike , changed the oil and after a bit it goes this colour
where can it get contaminated from ?,read somewhere bout non return valves ???? i found 2 rubber tubes off engine both are open ends. one finishes up by rad and other finishes in skid plate.
Old 03-15-2008, 09:13 AM
rockyroad rockyroad is offline
Water can enter through your breather hoses or it can be the coolant. I say you warm the engine, drain thoroughly, change the oil and route both hoses upward. Ride and avoid water crosses for a while to eliminate the possibility that this is the culprit. Water pump gasket(s) are next step IMO.
ec 300 transmission oil jetfish Enduro Engine - 2 stroke 32 10-27-2010 05:00 AM
Noisy transmission 07 fsr 450 fastisbetter Enduro Engine 4 stroke (including EFI & Exhaust) 6 04-08-2010 07:20 PM
No oil in Transmission RPB111 Enduro Engine - 2 stroke 5 03-17-2007 08:49 AM
EC250 '00 transmission in MC250 '05 Leon_gasgas Enduro Engine - 2 stroke 12 01-10-2007 03:10 AM
