wear in rear linkage HELP
recently got a 99 ec300. lots of up and down play in the rear so changed out bearings and bushings..play not so bad now but still there. the bolts seem a bit sloppy in the bushings and also in the dog bones (link arms)...can you say if the bolts are likely to be worn and also the dog bones...where is a good place to source these in the uk....thanks in advance
Welcome to ggrider.org
I don't think the bolts or the dog bones are worn. Usually, the bearing get worn out which allows the bushings to have excessive play. You may find the bearing kits here...... http://www.trialendurodirect.com/index.php |
It sounds like all your bearing are good, once you know this for certain lube it all up assemble and just barely start to snug the bolts up. Then I use a rachiting tie down from one side of the swingarm over the seat and down to the other to preload the whole system, now go back and tighten everything down to spec or a bit more. BE CAREFULL to get the lower shock mount just right and not to tight as it is aluminum. This should take every last mm of play out of the system. Those 99's were sweet! YOU should know they turn everybit as good as the new ones. The Nickel frame is way cooler than the powder coat as well, not my opinion but fact.
i have put in new bearings and bushings but still sloppy even with all tightened up the linkage had been seriously neglected by the previous owner to the extent that the old bushing was actually broken in half will continue to hunt for bolts and bones |
Are you absolutely sure the shock is not moving? If the top shock bearing is bad or if the shock needs servicing it could be moving. Just a thought.
same thing
I bought a bike that had just had new bearings put in although it appeared to have been waaaaay to late.The swingarm bolt ,the engine cases ,and linkage from the swingarm bolt were all ruined. Check your swingarm bolt for grooving and cases for oblong hole.hope its not but check those.
Stoby |
My 99 EC 300 was just the same, talk to Dave at Biketech in the UK he'll know the answer and have the bits too.
The holes, cases and bolts only get hogged out if the bolts are loose. The bolts hold the bushings captive and don't need to be perfect. The top rarely wears out.
was out today for the first in a long time...lots of really tight gnarly ruts in the woods...loads of mud......no grip.....absolutely knackered and very shocked by how unfit i have become.....must get out more |
If every thing is properly tightened there is no play in the system. Of course you want top notch hardware but even with worn hardware their is no play in the system.
More oil = less wear | Eric K | Enduro Engine - 2 stroke | 16 | 01-31-2010 05:49 AM |
Rear linkage brackets lower mount | 3hunerd | Enduro Suspension | 2 | 10-16-2008 09:42 AM |
Clutch max min wear? | brains | Enduro Engine - 2 stroke | 1 | 07-26-2007 02:50 PM |
Zerks for rear linkage? | mike989 | Enduro Suspension | 7 | 06-17-2007 06:50 PM |
LTR needle wear | mattmax | Enduro Intake/Carburetion - 2 stroke | 11 | 03-08-2007 10:09 PM |
