Old 11-07-2013, 02:55 AM
Vinny's Avatar
Vinny Vinny is offline
Default GG 450 high idle
Bike runs great, just idles too high. On steep downhills its actually accelerating on 1st gear.
Any ideas on how to lower the idle a little bit ?
Its an '05 GG 450 FSE.
Thanks.
Vinny
Austin , Tx
A wonderfully working and hard riding '05 GG 450.
Old 11-07-2013, 04:11 AM
Marco Marco is offline
Thanks.
If it ran OK to start with I would check your cable is not caught up somewhere or slightly frayed at one end and getting snagged internally on the cable cover
. It can get caught in a number of places particularly if you have had the tank off. Check that it is properly seated at both ends.
Not sure you can adjust idle manually. I never did on mine but someone else may correct me.
Old 11-07-2013, 05:24 AM
Vinny's Avatar
Thanks for the quick response. I had that problem when I added an inch to the handlebar. I took it off.
I'm looking for a way to adjust the idle. I tried the computer diagnostic tool a while back, it didn't help.
Vinny
Austin , Tx
Old 03-14-2014, 09:14 PM
Nick's Avatar
Nick Nick is offline
There is an adjustment on the throttle body that is accessed from the back of it.
Old 03-24-2014, 06:00 AM
Vinny's Avatar
Default I'll look into it
I haven't seen a screw back there. While I'm checking the valves I'll take the cover off and look for the screw.
Thanks. I hope it's there.
Vinny
Austin , Tx
Old 06-12-2014, 04:39 AM
Vinny's Avatar
Found what I think might be the screw. No change when I move it. Might be wrong screw.
Picture available ???
Vinny
Austin , Tx
Old 06-12-2014, 10:32 PM
Why Z? Why Z? is offline
I am no expert, but have you checked for air leaks at all?
Just thought I would suggest it before you go through the trouble of tearing down the bike.
I just thought it could be possible that you have air leak in the intake somewhere, I suspect a similar problem (w slightly different symptoms from you) bt a lot of what I have read sounds kinda like what you are describing.
To test it spray anywhere with short bursts of crab cleaner, starter fluid or something flammable where there could be a leak.
Or I could be totally wrong guys so if I am telling him to do something dumb go head and call me out on it n tell me why!
High bar question lgr Enduro Chassis & Body 15 08-26-2013 07:30 PM
Idle REALLY high after carb / PV clean SingleTrackMind Enduro Intake/Carburetion - 2 stroke 8 07-22-2013 09:58 AM
ec 300 2005 won't rev high nor idle... hannesd Enduro Engine - 2 stroke 23 12-17-2012 01:52 AM
Way high in the cascades PEB Pictures & Videos 16 09-16-2011 06:38 PM
Very high idle problem rupecopp Enduro Engine - 2 stroke 5 10-22-2007 05:51 AM
