Ignition coil question, EC300, m.y. 2009
I have a very weak spark, and the engine is not starting. Prior to this happening,
- the engine sounded really rough and vibrated quite a bit - right before stalling, it would not idle, but remained running a few seconds with applying the throttle - then it died - during the previous two times I had been riding, the odometer would go nuts and show only 8888's when revs went above 7.000 rpm. I am not sure if this is related to the present problem So, I am not 100% sure if I have: - a malfunction in voltage regulator - an issue with the carb - an issue with the ignition coil Anyway, the spark is very weak. I have checked that the plug cap gives 5 kOhm. When I measure the coil, I get 6.2 kOhm between the spark plug connector (2nd for the bottom) and the thin lead which goes inside the coil housing (1st form the bottom). I also get the exact same resistance between the plug connector and the thin terminal (1st from the top). Resistance between the thin connector (top-most in the image) and the thin lead (bottom) is 0.3 Ohm |
EC300 coil | Dutch | Enduro Electrical & Wiring | 3 | 07-13-2019 03:58 PM |
Ignition coil | Gassedshaun | Enduro Electrical & Wiring | 0 | 12-24-2017 04:35 AM |
2005 (maybe other years) ignition coil | Vinny | Parts | 0 | 09-21-2016 11:58 AM |
Ignition coil | davedunaway | General Discussions & Announcements | 2 | 09-04-2012 12:22 PM |
