2018 XC300 No Spark
Hey all,
I went out for a ride yesterday, unloaded the bike and fired it up. it ran for about 30 seconds and died like someone had pressed the kill switch. I was not able to get it running so i took it home and tore it apart. Upon checking everything, i have discovered it has no spark. I disconnected the killswitch to rule that out, changed the sparkplug, made sure it was firmly in the sparkplug wire. I am not sure where else to start, i am mechanically inclined but not the best with electrical. Had someone tell me that the stator might be failed, but i dont have a multimeter to check it, or know what exactly im checking for. Any suggestions would be great, i was thinking about just replacing the stator and the coil. Appreciate it. |
I have heard of the CDI module failing.
Is the another GasGas there you can swap parts with? |
+2 for the CDI, dealing with this on my 18 GP.
Dick Carnes "If ya run, you'll only die tired" 2019 EC 300 2018 GP 300 2013 XC 300 (sold) 2006 DE 300 (buddy has it) |
Before throwing parts darts, you can a pretty cheap multimeter and at least check some resistance readings. They are listed in the manuals that gasgas has online. If you get a meter we can pretty much walk you through the tests
As above do not go throwing parts at it. Test it first, there has been confirmed reports of sheared ignition rotor keys stemming from loose rotor bolts and will kill the spark.
Hey guys. thanks for the information.
I'm going to have a look at it when I get home and have someone help me check some of the electrical. Parts have been a tad tough to find right now due to whats happening with GASGAS. |
Just been out done @ 7 miles bike ran fine stopped for 5 mins and it struggled to restart cranks no problem back fired a couple of times eventually started but ran poorly managed to get within 1/2 a mile of the van and that was it no more the spark is missing bikes only done 20 hrs.
key way on the flywheel sheered making your timing off ( history of this ) CDI is bad (also history of this)
While we on the subject of no spark, anybody know if a CSK CDI can be remapped to a CRB CDI?
Thanks for the reply I think if the key way had sheared I would still have spark I?ve borrowed a vid of my pals bike will let you know tomorrow how I get on.
2018 XC300.. more power? | Islander | Enduro Engine - 2 stroke | 4 | 05-27-2020 07:10 PM |
Wanted 2018 xc300 | gaser | "Wanted to Buy" & "Want To Trade" | 0 | 12-02-2018 12:56 PM |
Need help deciding... 2018 XC300? | Wypipo | Enduro Product Reviews | 17 | 09-16-2018 10:44 PM |
Debugging no spark on '14 XC300 | CombatYoga | Enduro Electrical & Wiring | 12 | 01-07-2018 10:29 PM |
Picked up a 2018 XC300! | Adrian200xc | General Discussions & Announcements | 8 | 11-06-2017 09:09 PM |
