450fse tuning
Hi all, I have an 03 450fse, need to do a bit of tuning, i have the MDST v1.7 software plus the serial cable with the little grey box on it , when i run the software it gives the error no hardware key, can anyone give me any advise where i am going wrong?
With the Technoresarch VDSTS you can get two versions of software. A pro version or a standard version. The standard version just requires the correct cable and adaptor box to work. The pro version needs a dongle or hardware key to work. The software maybe looking for that.
If you think the software and cable are compatible then the first thing to check in the program is that you have the correct com port selected. On the menu bar select "communication", then select "Port setting" and set the port number of the serial port you are using. Then to check if the programe is connecting to the cable, go to "Veiw" on the tool bar and click on "Vehicle Interface cable properties". These menus are in my version of software and as yours is probably earlier the names and position of menu commands my be dfferent. If you want you can download the latest version of software from the Technoresearch site, for free. Hope this helps, Stu |
hi stu, tried what you suggested, but still no joy, downloaded the one from technoresearch , ports configured ok, nothing shows up on the test apart from it telling me to turn ignition off hten on., struggling with the sentinel drivers i think
Hi JJ,
bummer that what I said didn't help. You will need to go through and check the basics. Does your computer have a serial comms port or is it going through a USB to serial adaptor? It would pay to check the comm port set up in your computer's "Device Manager". Make sure the port is there and working and also what com port number it is. Then make sure that the VDSTS is set to this com port. Some of the USB to serial adaptors are not always compatable with some devices. When I got my cable I had a problem with it not communicating, but that turned out to be the wires between the ECU and the Tecnoresearch box being crossed over. I could see my box in the software but it didn't communicate with the bike. Spent time & money a some long distance phone calls to Technoresearch but eventually figured it out myself. I don't think yours is the same problem though. If all else fails you my need to ring Techno and talk it through with them. Cheers Stu
Now 50% of Dirt Action Service, Christchurch, NZ |
thanks stu, i have been in contact with technoresearch via email, but they are slow replying, com ports set up ok, the software cannot even see the dongle attached to the serial port,
quick question, if you have the standard version do you need to load in the sentinel drivers? |
The older versions will not work under XP or Vista.
I cannot remember which version I have (not in USA at the moment so cant check) but it requires a win95 or win98 OS to allow the sentinel crap to install properly. The version I have requires a parallel port for the dongle (hardware key) and a serial port for the cable. The cable I have has an extra socket at the bike end to supply power to the el cheapo interface convertor built in the serial plug. This is there because some PCs (especially laptops) cannot supply enough power through the serial port to run the level convertor. Worth a check maybe? Hope it helps |
Suspension Tuning 101 | MattR | Enduro Suspension | 3 | 06-21-2013 10:50 PM |
Website tuning.... | webmaster | General Discussions & Announcements | 17 | 10-09-2010 12:13 PM |
Carb Tuning Info | Rick | Enduro Intake/Carburetion - 2 stroke | 1 | 12-27-2009 07:24 AM |
GasGas sm 125 tuning | EmilO | Enduro Engine - 2 stroke | 0 | 08-14-2007 05:18 PM |
Tuning wild hp 450 | gvanminnen | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 05-05-2007 03:56 PM |
