Old 04-26-2012, 09:24 AM
Diggs345's Avatar
Diggs345 Diggs345 is offline
Default 2009 ec300 sachs suspenders
Hi all
I had chance to try my new bike for a short time yesterday over some rough whoopy ground and initial impressions are that it is set up very hard ,mif i was young a fit and riding it in motox maybee not so bad , but im 44 and not so fit due to being off a bike for two years.
Is it worth replacing the saches shock for an gas gas ohlins damper or just get the saches shock revalved along with the forks.
We have a guy who works for the gas gas team called steve plain who iv heard good things about.
Any advice would be much appriciated.
Chris
Old 04-26-2012, 06:32 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
The Sachs shock is fine, it has two known problems, the energizer o ring under the piston band can be too small and wear quickly causing blow by and loss of damping and the ball bearing check valve can 'moan'. Both have easy fixes detailed in many threads. My bike and other also have squeaky shocks which I'm near certain are the seal, just sounds bad.
As for action, it is a good as you'll gt once set up correctly, I use a racetech gold valve and valving, mainly for the new piston band setup.
A revalve and it should be great.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 04-26-2012, 08:46 PM
Diggs345's Avatar
Thanks , so your saying just revalve the sachs and dont go for a ohlins rear .
Chris
Old 04-27-2012, 01:54 AM
Simmo737's Avatar
Yep, it's actually good quality steel bodied with good tolerances. Cheers.
Oz
1978 GT80 Yamaha
Old 04-27-2012, 05:49 AM
I am guessing that the previous owner did a revalve on the forks. You normaly only notice the rear once the forks have been fixed
Old 04-27-2012, 08:16 AM
GMP GMP is online now
If the tuner is good he will update the shock with the correct parts. Once this is done and its sprung/valved for you its as good as an Ohlins.
Old 04-27-2012, 10:53 AM
Diggs345's Avatar
Not that i know of , the whole bike seemed set up very hard , i knew the forks were going to be hard from what id read on the net , i just wasnt sure if it was worth swapping the shock for a ohlins as there is one up for grabs used.
Chris
2009 SACHS Shock Question 300XCRider Enduro Suspension 4 02-16-2011 07:59 PM
Nabotin EC300 Replica 2009 cladoo Enduro Product Announcements 7 02-08-2009 06:23 PM
