Old 07-08-2018, 01:52 PM
Having the squish tight will help reduce detonation through better cooling of the piston crown. But you have to reduce the compression down to sensible levels. That will naturally cut into the squish area a bit and bring msv about right.
Clearly the piston crown should be parallel to the head. Wedged shape is not a tool required with a reasonable engine on OK fuel. And never a wedge closing in to the center.
Old 07-08-2018, 04:53 PM
and comparing fuels between straya and usa you have to remember we use RON as our standards and they use MON.
Old 07-08-2018, 06:44 PM
Gibnut Gibnut is offline
So, Rick?s 91MON is roughly equivalent to our 95RON, correct?
Gas Gas 2018 EC250 Six Days - sold
Old 07-08-2018, 08:57 PM
And farrenheight instead of sellyoususs for temperature although we should really be using kelvinklein degrees
Old 07-09-2018, 03:38 AM
Something like that..
95RON is closer to 85–86MON... which is about 91 PON (Pump Octane Number)
Old 07-09-2018, 04:25 AM
Fieds83 Fieds83 is offline
Fieds, if your bike is a GP it has a different head to my EC. We would all love to see how it?s shaped by S3! My barrel has the S3 logo stamped on, too.
Rick D - Dave at Two Stroke Performance has said with appropriate jetting, there?s no reason why my bike won?t run well on 91 octane fuel. I am lucky enough to have good 98 around the corner from my house, though..
Mine is an EC mate, i would like a GP but the deal i got on the EC was too good to pass up.
Old 07-16-2018, 01:47 PM
AZRickD AZRickD is offline
A response to my email:
HI Rick
Thanks for the email
Yes, we offer that service where you send in your head and we either re-chamber it or machine it to accept our billet insert
We also have the billet head available now for the 2018 and newer 250 and 300..
Feel free to call anytime
Kelsey
208 852 3221
RK Tek Inc
Old 07-16-2018, 03:03 PM
Email #2
We completely re-configure the chamber.. We have done ALOT of testing with the Gas Gas and have got a chamber design that is woring very well. Compression ratios vary with elevation and octane.. We do NOT just have 1 chamber for everybody.. not the way we roll.. everyone is custom tailored for the application
Cost to rechamber i $150
Billet head is $325 and we only have a few in stock.
Old 08-01-2018, 05:09 AM
My bike is now fixed. I had the head cut by TSP (Australia) to lower squish to 1.35mm. I also had a closed-throttle lean condition caused by the slide being too high. This was throwing up red herrings regarding jetting & compression.
Running perfect.
Old 08-01-2018, 12:32 PM
Yay !!
More data points.
2018 Ec300 Jetting Specs Mud-Ectomy Enduro Intake/Carburetion - 2 stroke 53 11-17-2021 01:48 PM
Richer jetting after squish more? adriano.ro Enduro Intake/Carburetion - 2 stroke 4 12-27-2017 01:17 PM
05 ec200 squish, cc's, jetting Zrt1200 Enduro Engine - 2 stroke 14 05-21-2016 04:12 PM
Jetting, S3 heads, Squish band, and other fun stuff! memphis2857 Enduro Engine - 2 stroke 5 07-31-2015 04:15 AM
2011 GG 300 SD squish, comp, and jetting data Sixdays Enduro Engine - 2 stroke 50 04-02-2012 07:17 PM
